696 headlight - lighting inadequate?
Started by Sleeper_I, May 12, 2009, 03:36:05 AM
Sleeper_I
696 and possibly monster 1100/s owners, is it just me or does any of you think that the level of lumen produced by the low beam is inadequate for night rides? I find that my low beam is pathetic compare to cager's low beams and that my high beam will match. If I were to stared straight into the high beam I won't be blinded like I would if I had stared into my car's high beam.
I've been using my high beam and never had a complaint nor anyone flashing back at me......hmmmm
herm
i feel the same way about the headlight on my s2r1000. my solution was to
1- put in a halogen bulb
2- adjust the aim of the headlight up a bit
not sure if either is an option for the new monster, but worth a try if it is.
z0mb1e_DUC
someone on this board swap'd the stock bulbs on the 696 for Sylvania Silverstar Ultra's.  I did this with my truck, it made an amazing difference.  It's a much whiter bulb with greater reach & shows more detail.  It also makes the reflective paint used for lanes, signs & markers show up much better.
'09 m696 Dark
Before doing anything else, check the headlight aim.
Binary
2009 Monster 696 - Dark
Spicoli
I put silverstar bulbs in mine and made a big difference.  I don't really feel it is inadequate anymore.
I have a set (high, low & running light) for sale if you want (selling my 696).
Life's too short to be taken seriously.
'09 Triumph Speed Triple, flat black
1313
09 M696
Armor
Look in the owners manual and set your headlight aim.  First adjust the sag and suspension.
