Can I use Kerosene to clean clutch plates?
Started by Jordan, May 17, 2008, 09:13:01 PM
Jordan
I just replaced my open clutch cover with another open clutch cover.  I noticed some fine power "dirt" on the outer plate.  Should I be concerned about this?  Wasn't much but I'm going to be putting in new springs soon so I'll have it apart again.  Can I use Kerosene on the plates?  Is it straight forward to take apart and clean?  Do I need a special tool?
Thanks,
jordan
99 900ss
Quote from: Jordan on May 17, 2008, 09:13:01 PM
Thanks,
jordan
Don't use kerosene. Kerosene is oil. Oil makes a dry clutch slip. Brakeleen would be a better choice if you feel a need to clean things, or you could just blow the dust out with compressed air. Wear a mask.
It's very easy to take apart. The spring retainer screws don't need to be very tight.
Jordan
#2
Quote from: ducpainter on May 17, 2008, 09:16:48 PM
Ok I'll get in there with some of that canned air.  BTW how dirty is dirty?  I assume some metal dust is normal even with an open cover?
I'm itchin' to use my new torque wrench so the springs will be torqued to spec.  [thumbsup]
99 900ss
Quote from: Jordan on May 17, 2008, 09:19:49 PM
I've only cleaned mine out twice in 30K miles. I wouldn't worry.
Be very careful with those screws. They break easily. I wouldn't torque them, Just snug them.
Ddan
Quote from: ducpainter on May 17, 2008, 09:29:03 PM
+1
When the screw stops turning, stop turning.
Ducati Monster Forum at
www.ducatimonsterforum.org
printman
I like to use a longer T-handle so it will flex before giving too much torque
I'll update this later at a convenient time Thank you for tuning in.....
