January 10, 2025, 03:53:52 PM *
Author Topic: Oil Cooler  (Read 1913 times)
Nookx
« on: May 17, 2009, 02:49:16 AM »
Hi, Ive had my M600 for a few years now and whist I often lust over the newer and bigger models, I just cant bring myself to part with it.  So! Ive decided to do a few mods... I would like to fit an oil cooler to it, but Im not sure which oil coolers from the other Monsters would be suitable, there is one available to me from a 750 model, but again I m not sure if it would fit.  Can anyone offer any guidance?  Thanks.
« Reply #1 on: May 17, 2009, 05:43:53 AM »
It will fit.
You may need some fittings for the cases.
I'm going to move this to acc&mods...
The guys there will point you in the right direction.
teddy037.2
« Reply #2 on: May 17, 2009, 08:11:05 AM »
if you're going to piece it together, you'll need a cooler (IIRC all of the 2V OEM mount the same), valve cover w/the threaded extensions to fit the cooler, lines, and that bypass valve thing that mounts inline between the engine and your oil filter.
DP sells kits, which save you alot of legwork, but is pricey.  the install itself is quite easy  waytogo
I did the same for my 620
moto
« Reply #3 on: May 17, 2009, 09:49:31 AM »
H-Competition is working on a high quality oil cooler kit for the early monsters.
The one we received for the M696 had titanium mounts....
H Competition Oil Cooler M696/1100
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
« Reply #4 on: May 17, 2009, 10:28:48 AM »
^^^  That's well and good, but where's the bypass flapper valve that goes between the engine case and the double-ended stud which mounts the oil fitler?
teddy037.2
« Reply #5 on: May 17, 2009, 12:58:37 PM »
sure is pretty...
which reminds me, I want to look into new lines for mine... the chrome's flaked off most all my fittings
moto
« Reply #6 on: May 18, 2009, 08:08:36 AM »
Not pictured but included.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
