September 01, 2024, 12:19:31 PM
Resistor strength required for indicators in integrated LED taillight?
Topic: Resistor strength required for indicators in integrated LED taillight? (Read 4427 times)
Grug
May 17, 2009, 02:11:25 PM »
Hey Guys,
I have a Motodynamic Integrated LED taillight on the back of my monster, which needs some resistors for the indicators (they're flashing way too fast), however I don't know what sort of strength resistor I need.
I've been told a 25 watt 8 ohm resistor will do the trick - but I can't find a resistor with stats even close to that anywhere (only either 8 ohm with much lower wattage, or 25 watt with much higher ohmage). Does anyone what will work?
I just want to pick them up from the electronics store and get it all wired up without having to run back and forth trying different options.
Any help would be much appreciated.
Cheers,
Mark
Charlief
Re: Resistor strength required for indicators in integrated LED taillight?
May 17, 2009, 03:46:47 PM »
I just wired up an LED tail light with signals on a friends bike and we had the same problem. I had him order the Rizoma resistors thru PJs Parts. Wired them in and everything worked perfectly. I'm not sure what the rating is on them but for the 20 bux or so they might be worth it.
Hope this helps a little.
Grug
May 17, 2009, 05:31:10 PM »
Quote from: Charlief on May 17, 2009, 03:46:47 PM
Cheers, I've looked at the resistors from PJ's Parts and a couple of other US companies. But with shipping I'd end up paying close to $30 for a couple of resistors that should only set me back about $1.30 (tops) from an electronics store here.
Scooter-Trash
May 17, 2009, 05:34:53 PM »
Radio Shack (it's about the only thing they're good for
Alternatively, go for an aftermarket flasher unit like Kisan.
Solid state flashers don't care what you connect them to and can give you nifty features like running lights and signal flashes when you brake (but it runs about $100)
4DoorSi
May 17, 2009, 06:49:36 PM »
You won't find anything at radio shack....
You need something that will take a lot of heat and be able to dissipate it. 8 Ohm, 25 Watt sounds about right. You aren't talking about some tiny resistor that you could put on a circuit board, you need one with heat sinks and such.
Sorry, you will most likely have to put up with the fast flashes until you order something.
Scooter-Trash
May 17, 2009, 10:53:37 PM »
Quote from: 4DoorSi on May 17, 2009, 06:49:36 PM
Maybe at yours. I was just in there last week and they had big-ass ceramic 25w resistors in several ohms values (from 6 up to 12)
4DoorSi
May 18, 2009, 07:03:23 AM »
Ok, guess my radio shack sucks....
Every time I go in there looking for something, they don't have it.
Bones
In spanish she calls it
'02 M620 - '00 996
May 18, 2009, 07:15:38 AM »
Quote from: 4DoorSi on May 18, 2009, 07:03:23 AM
No, radio shack does have the right resistors b/c I've bought several for my bike and cars when I converted to LEDs. I don't have the part number but can post it when I get home tonight.
I'm a loner, Dottie...a rebel...
jfisher2
May 18, 2009, 11:26:49 AM »
+1 on getting electronic flasher...$12 at auto zone to replace your flasher unit (simple unplug and plug in new one) rather than having to wire in resistors. This is definitely the way to go.
97 M900
Scooter-Trash
May 18, 2009, 01:12:02 PM »
Quote from: jfisher2 on May 18, 2009, 11:26:49 AM
Damn. I had no idea they were that cheap. You'll probably have to wire in a grounding wire, but that's easy.
greenohawk69
May 18, 2009, 01:39:41 PM »
Does this apply to all bikes or are there certain years this will or will not work? I have a '97 M900.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty: Soap, Ballot, Jury and Ammo. Please use in this order. -- Ed Howdershelt
Grug
May 18, 2009, 02:18:10 PM »
Damn, wish I'd heard about the "flashers" earlier - they're not too hard to find down here apparently
I've gone and bought some resistors off ebay, but when I go to pay for them I keep getting directed to a non-ebay site, and that's not a risk I'm going to take - which means that now I have to faff around with the seller to sort something out.
Patience, when will I learn patience?!
JEFF_H
May 18, 2009, 02:44:23 PM »
on 02+ bikes the flasher is controlled by the computer not an external box.
Charlief
May 18, 2009, 03:49:43 PM »
Quote from: JEFF_H on May 18, 2009, 02:44:23 PM
Yup... or in the case of my S2R its in the gauges cluster with no user access.
Bones
'02 M620 - '00 996
Reply #14 on:
May 18, 2009, 03:59:57 PM »
for those interested, this is the Radio Shack part no:
#271-0132 (13-ohm 10 watt 10% tolerance) wirewound resistors.
This is what I've been using for all my LED applications to put a load on the circuit. works just fine.
One end to ground the other to hot (install in parallel, not in series)
