Battery tender cable uses
Started by Danmack_98, May 17, 2009, 07:19:48 PM
Danmack_98
I just found the battery tender cable on my 696.  Is that all it's good for or can it be used for other things also?
"That bike looks like if you knocked it over, it would stand itself up and kick your ass!!"
Bones
uhmmmm...besides charging your battery?
suppose you could also use it as a power lead.
I'm a loner, Dottie...a rebel...
Danmack_98
so it could be used for heated clothing or other powered accessories i'm assuming.  Do heated clothes-gloves come with a compatible cable?
Do not use it for anything above the rating of the fuse that came in it.  If you get heated clothing it should come with a suitable power lead.  You can install that one and use it for your battery tender.
Mash
Quote from: howie on May 18, 2009, 07:16:13 AM
That's really the key here.  Don't use the battery tender cable for anything that will draw more power than the cable is rated for.  There's a fuse in that tender pigtail, and that should give you an idea of power rating.  Don't be tempted to put a bigger fuse in there, you could melt the wires.
I think you could use the pigtail as a power lead for small electronic devices, like phone chargers or GPS.  Heated clothing may be a bit much.
I know for a fact that you can't jump start your bike by attaching another battery to the tender cable.  Ask me how I know.
'06 S2R1000
I have indeed installed a slightly  higher rated fuse and other than using my battery tender cable for it's original purpose I also use it to connect to and run a miniuture (and I mean tiny) compressor that in the event of a puncture I can use to reinflate my tyre.  I also fitted an additional low-as-it-can-go fuse in the compressor side so that if I do draw too much current the fuse is easy to get to.   But no, I wouldn't use it to power a long high-load draw such as electric vest, mine's strictly for "get you home" emergencies.
I got a "cigarette lighter" that hooks up to the tender cable that I used to charge my cell phone while on a road trip...
mstevens
Quote from: Danmack_98 on May 17, 2009, 07:19:48 PM
Where exactly is this cable? I've pored over the manual trying without success to find it (the bike doesn't get picked up for a few days, so I can't go out and hunt on the bike itself.)
Is this a standard feature, or something added by dealers who want to drive psychiatrists out of business by minimizing the need to access the battery?
ManOrAstro-Man?
Yes, where exactly is the cable? Can you take a picture of where it is please? I keep reading about it being on the right side somewhere, but can't find it on my bike.
The cable isn't standard, so it won't be in the manual. It will connect directly to the battery and look like this
ProTeal55
Quote from: KG5 on July 17, 2009, 10:42:21 PM
You can pick up one from your local bike shop for around $5 (if their isnt one on your bike allready)...
Most dealers put them on as part of their prep (to aid in B.Tender sales)...
Member: Half Fast Chicago
Website:
ManOrAstro-Man?
Thanks Nakid. I know what the cable looks like. I had the same cable installed on my old 620. I've just been reading that it's installed on the right side somewhere on the 696. I've looked and looked and couldn't find it. I guess it wasn't installed on mine by the dealer. I have the cable. I haven't had a chance to ride it in the last few weeks and I have close to a full tank of gas in there. I'll have to take her out for a long spin this week to burn some of the fuel off. Then I can lift the tank and install my tender cable. Will also install the yellow colour therapy panels that I just picked up today as well at that time.
If it is a Battery Tender cable the gauge wire is too thin for high power consumers like heated clothing.  It will, of course, work with your Tender small power consumers like cell phones and GPS systems.
mstevens
Quote from: KG5 on July 19, 2009, 10:00:44 PMWill also install the yellow colour therapy panels that I just picked up today as well at that time.
Now you've got my attention!
I want to get a set of yellow plastics for my new-to-me 696 (that I haven't even picked up yet). I agree that the panel swap would be the perfect time to dissect down to the battery to mount the pigtail.
As far as I can tell, Powerlet hasn't yet released a specific kit for the 696. The kit for earlier Monsters is great. It looks as if the factory put it there, if you can even notice it. It provides a stable plug point with no connectors or cables flapping in the breeze. Even better, the wire is appropriate for heated clothing, etc. I'd feel much safer in a pinch using a Powerlet outlet to jump-start the bike than a Battery Tender pigtail. Once they do have a kit out I plan to grab a couple.
Jarvicious
Quote from: howie on July 20, 2009, 03:07:59 AM
I dunno.  I have a tender for both my bikes and aside from the fuse Amp rating, the wiring seems to be pretty similar.  My tech even said he's run his heated gloves off of the battery harness, you just have to add a higher amp fuse.  I don't really care to go look under my hood, but does anyone know off hand what the stock amp rating is for a tender and one pair of heated gloves?  I want to say 3A for the tender and maybe, MAYBE 5 for the gloves.  Kicking the 3 amp up to 5 on the tender harness really shouldn't be that big a deal, provided your tender isn't a raging piece of shit.
