April 26, 2024, 11:56:04 PM
$5 to the winner Where can I get Shoulder bolts - Wierd sizes??
Topic: $5 to the winner Where can I get Shoulder bolts - Wierd sizes?? (Read 6281 times)
erkishhorde
Re: $5 to the winner Where can I get Shoulder bolts - Wierd sizes??
Reply #15 on:
May 20, 2009, 03:30:07 PM »
Quote from: gage on May 19, 2009, 06:25:45 AM
$750!!!!
Ok so that ain't gonna work.
New plan:
Long Hex head bolt: 10mm x 1.5
Metal Sleeve: OD 12mm ID 10mm Length 20
24 mm OD fender washer
Think that will work?
Wow, never knew a few bolts could be so expensive.
TAftonomos
is without a monster :(
Reply #16 on:
May 20, 2009, 05:30:26 PM »
Think outside the box. They are available, and for a lot less money than that. If you give up PM me
MyDucParts.com
erkishhorde
Reply #17 on:
May 20, 2009, 05:33:39 PM »
I can check with my local shop called King Bolt but I can't get out there until the last weekend of May.
The sleeve idea should work perfectly fine.
g-force
09 M1100s Pearl
Reply #18 on:
May 21, 2009, 07:49:39 AM »
http://www.tastynuts.com/site/frames/frameset_shoponline.htm
on the left side of the screen, go to "DUCATI - SPECIAL OFFERS"
keep in mind that the lengths listed are the total length of the bolts (shoulder and thread) but know that the shoulder is the exact size you need.
scduc
Reply #19 on:
May 21, 2009, 05:32:37 PM »
McMaster is a good place to start. Chance are there is one in you neighborhood or at least not too far away.
08' S2R 1K That was close damn near lost a $400 hand cart.
Langanobob
Reply #20 on:
May 22, 2009, 07:17:55 AM »
I'm probably misinterpreting something, but why can't you just use longer regular bolts with your existing spacers? The shoulder bolts are probably the cleanest solution but it sounds like you may have to get them machined to get the exact ones you want.
Edit, Doh, after reading more, I see that sleeves or spacers are already under consideration. Amazing how the simplest change from stock always seems to bring unexpected consequences.
Last Edit: May 22, 2009, 07:43:33 AM by Langanobob
DarkStaR
Reply #21 on:
May 22, 2009, 07:33:52 AM »
http://www.tpoparts.com/catalog/product_info.php?products_id=86&osCsid=f64b3ce5a93e88f054a182c95282a136
