M900 Brake line redo....
Started by rgramjet, May 18, 2008, 10:37:44 AM
rgramjet
I mounted clip ons a while ago and the brake line slack is driving me nuts not to mention the cumbersome "splitter" that takes up so much room behind the headlight.
Ive been looking at a couple different setups.  One has a double banjo bolt at the lever with seperate left and right lines.  Today I was checking out pics of a 696 and it has a single line to a double banjo bolt at the right caliper with a short line hooping over the fender to the left side caliper.  Im kind of liking the latter setup....
Any suggestions/input?
TIA
-Sofadriver
clubhousemotorsports
spiegler (sp) makes lines any way you want them. check them out on the web.
Very nice quality.
A bit $$
That sort of set up is pretty common on faired sport bikes.  I think even some other ducs use it.
Don't see why you couldn't do it
I put that style on mine.
I bought it off ebay. It was listed for an earlier SBK.
I think you could use an SS style also.
The fitting angle at the caliper is the thing you have to watch for.
A.duc.H.duc.
Quote from: ducpainter on May 18, 2008, 07:39:14 PM
I'm looking at the SS and monster in my garage, and I'm sure you could use SS style lines, but they've got a split in the line that clips into the front fender. It'd work, but might be akward with out an SS fender.
Justin
Quote from: A.duc.H.duc. on May 18, 2008, 08:58:37 PM
Justin
The SBK line I use is almost identical and just sits there without the clip on the fender.
YMMV
A.duc.H.duc.
Quote from: ducpainter on May 18, 2008, 10:57:56 PM
YMMV
Oh yes, I'm quite confident all would work fine, just asthetically might not be the best with the t-fitting floating just above the tire.
rgramjet
No T fitting, just a double banjo bolt on the right caliper.  Single line from lever to caliper.  Connected with double banjo with line leading from right to left side caliper.  ala 696
-Sofadriver
