January 10, 2025, 05:56:53 PM
Anyone put a SportClassic fender on SBK forks.
Topic: Anyone put a SportClassic fender on SBK forks. (Read 1974 times)
dlearl476
May 24, 2009, 07:15:58 PM »
Since I threw in the towel on my OEM forks and decided to put on some SBK forks, my lovely DP painted front ender ain't gonna work. I don't really like the SBK fender, especially won't fit with my "Scramber" paint job. I saw a GT1000 and it's fender looked the bomb.
Anyone have any experience?
Feral 859
Re: Anyone put a SportClassic fender on SBK forks.
May 24, 2009, 07:27:59 PM »
Any fab guy can make you a bracket.
dlearl476
May 24, 2009, 08:26:52 PM »
I spent about 20 minutes talking to a parts guy I get parts from in LA. He took a look at one on the sales floor and he said he thought the bolt spacing was the same, but seemed to think the width was wider on the Sport Classic. I won't know until I can take a ruler to a dealership and check, but it seems weird to me that a Sport Classic would have a wider wheel than a SS.
Who knows. That's why I was asking if someone had done it. If it comes to that, I can make a bracket myself.
booger
May 26, 2009, 09:53:40 PM »
since SBK fenders will fit Monster forks, and the Sport Classic fenders seem to have the requisite 65mm spacing why then would a Sport Classic fender not fit an SBK fork?
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
DarkStaR
May 27, 2009, 12:34:47 AM »
Kind of depends on what forks you have, but it should fit.
The bands that goes around the fork legs are a bit different on the SC. The threaded portion is on the fender mount rather than the band its self.
Dannog
S4RS
May 27, 2009, 02:24:10 AM »
I have a spare cf fender from an S4RS which will fit on 999 SBK forks. PM me if your interested.
Last Edit: May 27, 2009, 02:31:52 AM by Dannog
dlearl476
May 27, 2009, 07:50:51 PM »
Quote from: bergdoerfer on May 26, 2009, 09:53:40 PM
Maybe I misspoke. I have forks off of a 2001 SS. I thought they were refered to as SBK forks, as they are different from (my) Monster forks. On my OEM forks, the mount is built into the top of the lower fork leg. On the SS forks, attachment is accomplished by plastic bands that go on the BOTTOM of the fork leg.
Quote from: DarkStaR on May 27, 2009, 12:34:47 AM
That may or may not be an issue. I just need to find some time to take a ruler down to the dealership and compare.
Quote from: Dannog on May 27, 2009, 02:24:10 AM
I don't think that will fit. Looks like it mounts front and rear. My mounts, afaik, are both on the fronte side of the fork.
Thanks, though. I appreciate the offer.
I'm trying to get this look.
As, IMO, it's cleaner and also more like the Scrambler fenders, to fit this:
Last Edit: May 27, 2009, 07:57:55 PM by dlearl476
DucHead
No garage queens
May 28, 2009, 03:31:42 AM »
If you're going for a Scrambler look, shouldn't you remove the flyscreen posthaste?
"45"
pennyrobber
May 28, 2009, 09:12:22 AM »
The older monster forks do have the mounting tabs on the forks and closer together than the bands. The mounting for the newer monsters, SS, and sportclassics are all the same band setup with the same distances between the bands. I have for sure seen SS fenders on newer monsters and sportclassic fenders on newer monsters so by A+B=C the sportclassic fender should work on your SS forks.
booger
May 28, 2009, 08:51:08 PM »
Refer to the new thread where a GT1000 fender mounted on a Monster is pictured; proof that it fits, so no need to spend any time measuring. If you do not have the 65mm axial calipers for the SS fork, you will need some or you will need to buy an adapter to mount your 40mm axial calipers to the SS fork. Have you thought of this? Are the SS forks adjustable? If not swapping them would be pointless. Especially if your current forks are adjustable which they seem to be- if I squint I think I can see adjusters on the top of the forks in your picture.
Have you actually priced a GT1000/Sport Classic fender? It actually comes in several parts- the mudguard part#56410561AA- $173.99; the RH holder part#82916861A- $98.99; the LH holder part#82916851A- $98.99; plastic clamp x4 part#74110341A- $4.99; fender clip x4 part#85040471A- $.99; screws x4 part#77510221A- $.99
All prices are from the Ducati of Omaha OEM parts lookup, and OEM parts prices are pretty much the same everywhere.
So, subtotal would be $399.85 from Ducati. I don't know where else you would get one since I haven't seen any on eBay. So $400 and you still need calipers or adapters, and since the mudguards aren't made in yellow, you would need to get it painted as well. I explored this myself and decided that it does look da bomb but the cost is prohibitive for something that offers no fork protection at all.
If it were me I'd stick with your current forks and fender to avoid the can of worms you are about to open. Doesn't look like your bike really needs anything at all. If you threw in the towel on your current forks because they are not working well for you then get them rebuilt and sprung for your weight and declare victory.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2008 BMW R1200 GSA
dlearl476
May 30, 2009, 10:59:07 AM »
Quote from: bergdoerfer on May 28, 2009, 08:51:08 PM
You say that like a $20,000 '99 M900 is a
bad
thing.
Quote
Looks can be deceiving. That pic was kind of a mock-up. My first try at putting the (old) front end together and a photo-op to show DP how his excellent work turned out. The boring details are in my "scramber replica" thread, but it all started with a pair of Alpina A-System wires that I got used, and were newer 25mm axle wheels. In the end, I came to the conclusion it was easier and better to use the SS forks than try to adapt the older 20mm axle to fit the wheels. I've already scored everything I need for the swap, save the new brake lines. I should get the last bit, the speedo drive for the wheel, back from the machine shop this week. My original forks are 3-way adjustable, which the new ones are as well, but in the end the ease of having everything in the fork/axle OEM won out over cobbling it together with a bunch of shims, bushings, and spacers. I plan on selling the OEM forks, which are Gold Valved as well, to help defray the cost. Should be a great upgrade from someone who wants to keep everything else stock, but has non-adjustable forks.
As for the OEM prices, I'm going to go sans fenders for a while. (you're right, the flyscreen and hugger don't really fit the "Scrambler" idea. It's just that when I had them painted, I didn't want to NOT paint those parts an regret it later. Easier to take off a painted part, than to decide I want it and have to go through the painting process again.) I'll keep my eye on ebay and make some calls to some breakers I know. If one doens't turn up some day, I'll pop for new ones from DUcati.
btw, THanks a bunch for the OEM parts numbers and prices.
dlearl476
May 30, 2009, 11:03:44 AM »
Quote from: pennyrobber on May 28, 2009, 09:12:22 AM
Thanks, man. The only thing that sucks is that I just ordered the SS fender clamps! I'm going to have to return them for the Sport Classic ones as it looks like the threads are in the fender and not the clamp. Oh well, the black clamps are better looking than the SS white ones anyway.
