Recommended Rear Spring weight
Started by He Man, May 25, 2009, 06:46:45 PM
What would you guys recommend for an S2R 1000 stock shock when the spring weight for max weight 160-165lb rider (with gear on)? the S2R sacks and 999 shock looks to be the exact same spring.
i have racetech .85kg/mm up front if that matters.
