bought two duc's this month, need carb help
Started by bennyrae, May 27, 2009, 07:35:48 PM
bennyrae
Hello, ,i  bought the wife a 2000 monster 750 for mothers day.  I liked it so much and found a "parts bike" on craigs list so decided to save it and bring it back to life.
I got it running pretty well off idle to 3/4 throttle but w.o.t. it falls on its face either while riding or stabbing the throttle sitting.
it has new 12:1 pistons, new timing belts valves adjusted carbs cleaned and orings changed.  It has aribox removed with clamp on K&N filters and stock pipes
I put 172.5 started jets, 150 mains stock needles on 2nd from the top..
any suggestions would be appreciated, weak coils? still lean on the mains??  bad diaphrams?( they look good)
please help me save this duc
mojo
Welcome to the DMF.  I can't help you, but you might get more help if you post this in the tech section
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
bennyrae
sorry didnt see the tech section,  its a 99 750 monster byt the way
dlearl476
Quote from: bennyrae on May 27, 2009, 07:35:48 PM
I'm sure someone with greater experience than I will step up, but I'd take a WAG that your carbs are "all dressed up with no place to go."
I think dlearl may be on to something.
Pullthe cans and see if it will take the throttle.
The intake setup you have kind of requires a freer exhaust.
