Tire ratings
Started by red baron, May 18, 2008, 08:36:49 PM
I LOVED the Angels on my 900SS.  Wet traction was excellent, and I had around 3500 on them when I sold the bike and they still had plenty of tread left!
Anybody ever run Bridgestone BT-016? I can get a BT-016 Pro and a BT-016 rear for $221.
What about Bridgestone S20?  I can run those for $230.
I would LOVE to run Angels, but they're pricey now it seems.
JM
I think I was right around $200 for just a 180 rear (regular diablo on the front)
That sounds like my findings, I can get a set Pilot Powers for $220, ContiMotions for $170 or Angels for $275 (but I would have to use a 170 rear and I'm not sure I want to).  I've never tried Powers, so I may give them a shot.  I got great grip from the ContiMotions, but mileage wasn't great.
JM
Quote from: the_Journeyman on July 02, 2012, 06:37:17 PM
JM
JM
Last set I got was Michelin Power Pilots, they're great, not so many miles yet, between weather and working from now . . .But, they do grip, still looking fr the TP to use them . . . 32/34 like I had the Dunlops seem not to properly work but when 32/32 . . . mpg goes way down . . .32/33 seems to be working the compromise but, never letting go of the grip . . . my 0.02 . ..
When my Diablo Rosso Corsas wear out I'll be fitting Conti Motions because I got them so cheap. They are a new tyre down here, so not much data on them.
Anyone have advice on tyre pressures?
I'm on a lightened M900 by 35lbs and I weigh 190. Grip means more to me than wear.
I've been running ContiMotions.  I usually run 35R and 33F which eems to do ok.  I can easily drag knees and hard parts on them.  They haven't lasted as well as I thought a stort-tour tire should, BUT for the price, they're really hard to beat.  I think I got about 4000 miles out of mine.
However, I have some funky wear, and while I've had a similar pattern  on Pirellis and Dunlops, it is by far the worst on the ContiMotion so far.  It's a really noticeable lip on the leading edge of the tread.  It's probably more my suspension than the tire.
JM
Thanks journeyman. I'll give those pressures a go.
Pirelli Angel 160/60-17.
Rear of my M750 commuter.
Down to the cord at 11.7k miles, 4 months and a week.
Worked great, other than the wearing out part.  [laugh]
Racka0
Pirelli Angel soft , best  rated motorcycle tire I heard. I bought a set to my Hyper 1100. After 4000 miles of hard riding in Pennsylvania the tires are like brand new. The middle section of the tire is very hard compound the side is same as diablo rosso corsas (softer to stick well).
I recommend I try  to all of you -and you will be happy with as much as I do. I do not even want to try other brand anymore.
Rickrides
Quote from: VisceralReaction on May 19, 2008, 09:04:21 AM
I have put 7K on a set of Avon Storms. Rear is just now ready to be changed out.]
I think I am going to go back to Pilot Roads again though
UPDATE,
Well I now have 8400 miles on the rear, it's very squared off and down to the cord.
I think it was a good tire all in all, did well in the wet, the front tire is still very good.
I think it squared off really quick though in about 4000 miles
My tire looks just like the pic in the post below mine.
Found a screamin deal on a Bridgestone BT-021 today so will review that next.
I have been running Avon Storm II Ultras on my modded 1999 Kawasaki ZRX1100 (100 hp at the rear wheel) for four sets now.  On one set I got 10K out of the rear and 9K out of the front.  Last rear was replaced at about 8K and the front is still on the bike but about due for replacement.  I ride mostly mountain roads, not much on the freeway or straight roads.  So, mine have not "squared off" too much.  They have been great tires.  Very confidence inspiring.
So, I am putting a set on the 2000 Monster 900 I recently purchased.  We'll see how they work on the Monster.  I was going to go with Avon's stickier tire but the place I bought them (American Moto Tire) did not have that tire in a 170 rear.
The Ducati and the ZRX wear the same size tires, which is interesting.
The first tires I put on the ZRX were Bridgestone BT-021s and the fronts cupped and the rears "squared off."  They didn't last long, either.  So, no more Bridgestones for me.  My wife's Yamaha FZ-6 has some Michelin Pilot Powers that have worn well.
2000 Monster Dark 900 ie
Anyone try these?
http://www.motorcycle-superstore.com/14/72/962/6175/ITEM/Shinko-003-Stealth-Front-Tire.aspx
I have the regular ones on my 450 sm (not the ultra soft) and they seem fine. I'm wondering how they'd do on a big bike though. I'm due for a front.
jerryz
#146
My S4 in thailand Pirrelli  Diablo Rosso corsa 3 s are shagged to the bone , thay have lasted really well but i only rate them 80%  for handling stability and comfort but 100% braking and 90% for grip , I really wanted Dunlops Q2 as i have had fantastic 100% results with m750 and SS750 in UK but none available here  ,at the moment
choice here is limited and tyres very expensive due to import tax ,for instance  pilot Road 3s are $450 a pair
they have Michelin Pilot road 3 in stock but i worry about reports that they dont work well in hot weather , should i go for them or not ,, Diablo rossos are available again too but i really want to try something different , I can get Pilot powers as well which might be better??? , and roadsmarts as well and all sorts of bridgestones but i have never ever liked bridgestone,  they seem very hard and uncomfortable tyres I have 3 days to make a decision
its very hot and sometimes very wet here now but hot hot & very 90f + with high humidity  all the time
kokis
Hi guys,
I am running Pirelli Rossa II on my m696. Previous was stock Battlax. I had 30\32 PSI pressure on old ones. And I damaged rim running on Rossa's at that pressure. Rossa is much softer and the country I live has very bad roads. Now I am running 39/39 PSI. While max pressure printed on tire is 42.
39\39 is good for me but I would like to set them to 40-41. Will it cause any problems running on max pressure? And what about if I am riding 50% time with passenger?
I am not pro in tech questions, but as any rider have some experience that I can share without claiming to absolute truth. Please use my advices responsibly.
SpikeC
 At the higher pressure the center of the tire will wear faster, making a flat spot, and you will have less traction in corners as the contact patch will not be able to spread and get more rubber in contact with the pavement.
You will get less "cupping" of the tread blocks, though.
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
kokis
#149
I know that, SpikeC [beer]. But what does max pressure on tyre means? What will happen if I ride at max pressure?
