MC Leak After Clutch Bleed???
Started by arai_speed, May 28, 2009, 11:05:11 PM
arai_speed
I recently bled my clutch and I noticed afterward that I have a small leak below the MC, right  by the microswitch.  See pic below:
I cleaned the area an inspected it and it look ok.  I went for a quick ride came back and noticed some fluid build up under the microswitch.  I would hate for brake fluid to leak all over my bike or gas tank  :o
Do I need to bleed the clutch again?  I'm not sure if this is just a build up or air bubbled in the MC that could be causing this.
My bike is a 07 S4RS and I bled the cltuch the old fashion way.
Any tips are appreciated.
Thanks.
Are you sure it wasn't just a little that you spilled when refilling the reservoir?
Bleeding won't stop or create a leak.
arai_speed
#2
Quote from: ducpainter on May 29, 2009, 06:27:35 AM
Yup, pretty sure.  I cleaned the whold area with a damp cloth and it sat overnight.  I then went for a quick ride and noticed build up.
There are no other leaks anywhere or build up around the MC, just under the microswitch.
Here is a pic I took this morning with no build up.
When I first bled the system, I noticed that I if pumped the cltuch lever and pressed the rubber boot, a tiny bubble would appear in the hole next to the microswitch, it did that only a few times and hasn't done it since.  I pressume this is where the leak is happening but can't be certain  ???
If it continues I'd suspect a bad master.
At this point if the clutch is working well I would just keep an eye on it  A leak at that hole would mean either a porous or cracked casting, both would be rare.  If it was the front brake I would be more concerned.
jerryz
The MC may be going south start saving now as the seals are unobtainable.I had to change my S4 MC
arai_speed
Thanks for the replies.  I'll keep an eye out it to make sure all is well.  I took the bike out for a spin yesterday afternoon and didn't notice any leaks.
How much would a new MC cost if this one is indeed going south?
Quote from: arai_speed on June 01, 2009, 04:38:43 PM
Look here:
http://www.yoyodyneti.com
