Oberon turn signals
Started by Ranger06, May 30, 2009, 04:41:30 PM
Ranger06
I just installed a set of Oberon bar-end Turn signals to clean up the front a little. I wasn't sure about them at first but I think I like them.  What do you guys think?  They seem brighter than the cheap-o LED's I had on before.
2008 695 Dark
This mod is one of the first ones I fell in love with [thumbsup] It seems like a very very good idea!
My only reason for not doing it is that I'm scared of how complicated it might be. Are you willing to do a write-up?
Ranger06
I wish I had thought of doing that before I installed them.  I did a good "How-To" when I installed my crankcase breather valve...I guess I was just anxious to slap these on.
It was really straight forward.  I removed the headlight to get better access to the wiring.  I removed the old turn signals and then (here is the scary part) I cut the connectors off the wiring harness.  I then installed the Oberon signals, ran the wires down the inside of the clip-ons, trimmed them to length, then soldered them to the wiring harness on the bike.  The lights themselves installed just like a set of bar-ends, with an expanding collet.  I shrink wrapped the connectors then hat was it.  Put the headlight back on and I was done.
Ever since I learned how to solder (youtube video), I have been a soldering junkie.  I have cleaned up so many wires just by trimming the excess, re-routing, then soldering them back together.
2008 695 Dark
No resistors? Was determining +/- required?
Ranger06
Nope, no resistors.  Wires were the same color as the Duc harness, black and white.  too easy, hooked them right up and they have a standard flash rate.
2008 695 Dark
hihhs
The Oberons look very trick! Awesome bike. The black on black tank looks great.
Monster 1100
redial
those look amazing. too good with the rizoma mirrors
i want these now, but my clipons arent open on the end near the triple, did you have to drill a hole to route the wires down?
Ranger06
Thanks
There was a plastic plug, which I punched out with a long piece of left over bar stock.
I really like the dropped look of the clip-on's and the low Rizoma's too.  I want a new headlight, then the front end will be done.
2008 695 Dark
Jarvicious
These are definitely on my list of to-do's, but I was wondering if they have an expasion set so you can use bar-end mirrors at the same time.  I have broad shoulders so standard mirrors just won't cut it, and I hate the look of the little extensions you can buy.
Quote from: Jarvicious on June 01, 2009, 08:48:36 AM
Did you find this?
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=605%7CLighting%2C%20Turn%20Signals%2C%20%26%20Mirrors&productID=6188&showDetail=1&categoryID=952|Adapters%20for%20Mirrors%20%26%20Turn%20Signals&vendoridtodisplay=0&filterFor=&collection=605%7CLighting%2C%20Turn%20Signals%2C%20%26%20Mirrors
FastAndLight
I really like that look.  My next set of mods include cleaning up the lights and looks of the bike.  I'm doing a tail chop, integrated rear taillight, black clip-ons, and some sort of cleaned up front blinkers....and these look awesome.
nikkimonster
sick. that is the tightest sh*t ive ever seen.
Jarvicious
Quote from: stopintime on June 03, 2009, 04:15:11 PM
Did you find this?
Stopintime, you're like the resident accessories lexicon.  In fact, I'm pretty sure you have most of the part numbers from monsterparts and motowheels memorized:)
