February 05, 2025, 11:05:43 AM *
Author Topic: Good Clip-ons for Monster?  (Read 6985 times)
Zak
« on: May 30, 2009, 08:01:36 PM »
I've been wanting to change up my bars recently and I like the look and idea of clip-ons.  I have some off of a Super Sport, but they don't fit quite right.  Any advice on some good clip-ons for a Monster 750?
Thanks,
~Zak~
« Reply #1 on: May 30, 2009, 08:17:35 PM »
Thanks,
~Zak~
You'll get better answers in Acc & Mods, so...
I'm going to move this.
rockaduc
« Reply #2 on: May 31, 2009, 05:22:24 AM »
Search around on here.  You will find that guys and gals have gone with Swatt, LSL, woodcraft, speedymoto, the list goes on.  There are quite a few threads on installation and trouble shooting as well.  You might have to lower your headlight and guages to accomodate the clipons, there is a tutorial on that as well.  Good luck and keep us posted.
Scoby2duc
« Reply #3 on: May 31, 2009, 11:54:35 AM »
I have the Swatt 1.5in rise mounted above the triple and I love it just far enough forward to really enhance the ride and easy enough on your back I love it
slowkitty
« Reply #4 on: December 22, 2009, 11:47:17 PM »
Hi, Scuby,
Would you mind posting or emailing me a pic? I am looking at those too.
Cheers
mattyvas
« Reply #5 on: December 22, 2009, 11:52:58 PM »
Speedymoto Tallboys on mine and love'em waytogo
cyrus buelton
aka JuddDDDdd
« Reply #6 on: January 01, 2010, 07:12:42 PM »
I'd find some used Cycle Cat's.
1999 M750 (joint ownership)
2004 S4r (mineeee)
slowkitty
« Reply #7 on: January 02, 2010, 04:36:30 PM »
Just thought I'll share my experience and what I learnt in looking for clip-ons.  It's mind-boggling and can be confusing.
First thing is to ascertain the fork size - usually 50 mm unless race forks were installed - then 53mm.
Next to determine is whether you will need clip-ons with risers or not, and the down angle.  Clip-ons can be mounted below the triple or above (steering geometry will be affected, they say), and risers can help with the lowered position of clip-ons somewhat, although I believe that no clip-ons can give you same or higher height than stock handlebars, except for 3.5 inch risers clip-ons mounted above the triple.  Some clip-ons cones in 2-piece so that the triple need not be completely removed for fitting the clip-ons.
From what I can gather,
CycleCats / Tomaselli - full adjustability, but usually spendy.
Apex - good value and adjustable down angles; 2-piece
http://www.monsterparts.com/pc/APEX1/Bars-Mirrors/APEX1.html
LSL - cool design and has risers
Woodcraft - has risers but no adjustability otherwise; 2-piece
http://www.woodcraft-cfm.com/Scripts/prodList.asp?idCategory=12690
SWATT - range of different height risers
http://www.swattmotorcycle.com/Clip-Ons.html
Motowheels - non-adjustable but comes with add-on riser kit if you need it.
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=1204|Monster&productID=2942&showDetail=1&categoryID=45|Monster%20Billet&vendoridtodisplay=0&filterFor=&collection=168|European%20Motorcycle%20Parts
There are others out there, speedymotos, DP etc, but these are the main ones that I come across time and again.  Hope that it helps.
Cheers
« Last Edit: January 02, 2010, 04:38:08 PM by slowkitty » Logged
