January 10, 2025, 06:59:13 PM *
Author Topic: headlight bracket mod  (Read 4302 times)
DarkDucati
il mostro scuro
« on: June 01, 2009, 01:56:33 PM »
Bike: ’06 S2R 800 Dark
Tools: hacksaw, dremel, bondo, high temp engine enamel primer and low gloss black paint
Parts: new Rizoma Zero 11 turn signals
I’m still working my way through a “how much more black could it be?” quest, so I decided to combine a few mods and paint a few more parts black at the same time.
I never quite cared for the shape of the stock turn signal/headlight bracket with the unused extra holes (after removing stock lights) and ridge along the top.  I also never plan on getting a wind screen and don’t like the unused mounting tabs sticking out, so I decided to make a few cuts and move the turn signal holes.
In the first pic below you can see the bracket where the turn signals mount.  I used the hacksaw to make a nice clean line.  Then I used bondo to fill the old holes, made new holes a bit lower.  On the U bracket I cut along that red line with a dremel and carefully removed the wind screen mounts.   I like the stock handlebar and gauge cluster height, and don't have welding equipment yet, so I didn't tackle lowering the U bracket parts like others have.  I think if I ever went with clip-ons I'd go that route next.
Once I removed the instrument gauge cluster and headlight, it was easier to see the mess of wires and where the U bracket was attached and how to get it off.
Had to clip a few zip ties and remove the nuts on the middle part of the U bracket  (I’ll call that the mini U bracket).  The two threaded parts w/rubber where the instrument gauges mounted screw in above the main U bracket. Those come out easy.
Crummy picture cut off at the bottom, sorry, but you can just see where the two bolts in the middle obviously need to come out to help remove the main U bracket.  This freed up the brake lines to pop out, but the U bracket was still well attached and not having done this before it was difficult to know how much force it should take to get it free.
Being careful I wiggled it and gave a few gentle taps with a rubber mallet and off it popped to reveal a plastic bit it slides onto on each side at the top.
Here are the bulk of the parts removed, ready for cutting, sanding, priming, more sanding and painting.
Here’s the end result. More black, and new Rizoma Zero 11 signals. Those things are bright, and you can see them from front, back, and side.  Also painted the ring around the headlight.   I think now I really need new black triples or black forks.
I should have taken a pic of the inside of the headlight ring.  Man that was a surprise.  I didn’t expect to see all these thin bent metal “needles” around the edge.  They overlap each other and lock into place to provide tension to keep the ring in place, that plus one screw.  Odd. Here’s a pic I snagged from the manual.
« Last Edit: June 01, 2009, 04:46:19 PM by DarkDucati » Logged
Current ride - Triumph Thruxton (don't hate, Ducs still #1)
2008 848 - R.I.P. (by delivery truck)
2006 S2R 800 Dark - SOLD
2006 Triumph Bonneville - SOLD
SikDuc
07 S4Rs
« Reply #1 on: June 01, 2009, 02:17:07 PM »
 waytogo
DucHead
No garage queens
« Reply #2 on: June 01, 2009, 04:01:10 PM »
Why not lower the gauges?
DarkDucati
il mostro scuro
« Reply #3 on: June 01, 2009, 04:45:51 PM »
+ I'm content with the overall height/position of things as stock and have always found it very comfortable even on long rides/trips I like to take.  Just suits me for now.
psycledelic
« Reply #4 on: June 01, 2009, 11:42:44 PM »
Nice job.  Looks great!
06 S2R800 - the wife                         Dolph
04 999s - the mistress
rockaduc
« Reply #5 on: June 02, 2009, 01:38:12 AM »
Very nice work!  waytogo waytogo
 Now that you have exp taking that front apart, it will be a snap when you want to lower the head light and gauges (it always gets done eventually) Grin
greenmonster
« Reply #6 on: June 02, 2009, 02:53:42 AM »
Looks good.
Pic fr a bit further out would be nice.
M900 -97
MTS 1100s  -07
DarkDucati
il mostro scuro
« Reply #7 on: June 07, 2009, 07:20:27 PM »
Looks good.
DarkStaR
« Reply #8 on: June 07, 2009, 08:38:56 PM »
+1.
I modded the u-bracket, and ended up re-doing it after lowering everything.
If you cut, prep, and measure everything, a local welder could probably tack it all up for a couple of bucks.  The welder I took mine to had a $25 minimum.
Mojo S2R
. Dark Mojo .
« Reply #9 on: June 08, 2009, 04:56:04 AM »
Nice write up.   waytogo
Very nicely done.  Bike looks great.
