Cutting seat post for Tail Chop.
Started by kprez007, June 02, 2009, 12:37:28 PM
kprez007
I did the Tail chop last night.  Wow looks great.  But the one thing I had to do was cut downthe seat post to make the seat lock down.
In doing so the seat sits a little bit more level and is even more of a comfortable ride.   Doesn't seem to be pushing forward now.
Did anyone else have to chop the seat post down?  If so did you notice the change?
Thanks
teddy037.2
#1
was it doing that before the chop?
is there any interference w/the seat/tail after the chop?
Mike_D
Quote from: kprez007 on June 02, 2009, 12:37:28 PM
Thanks
I recently chopped my 08 S2R1K using the CW kit.  The underside of the stock seat has two large plastic posts which I had to remove so they didn't interfere with the turn signal brackets.  Also, because I installed Rizoma turn signals without the extenders, I cannot put the seat cowl on.  Having said that, I didn't notice much of a difference in the forward slope of the seat.  I plan on converting to the DP gel seat soon as comfort on long rides with the stock seat leaves something to be desired.  Hope it fits.
2008 S2R 1k.  Black.  Pazzo Levers, 14 t front sprocket, CRG Hindsight LS mirrors, Cycle Cat Frame Sliders,  Oberon open clutch cover and gold/black EVR pressure plate, full Arrow exhaust with reflashed and mapped ECU, tail chop with gold Rizoma Avio 21 turn signals, Ohlins rear shock and Rizoma fluid reservoirs.
Scotzman
In the tutorials, there's a How to: Tail Chop (Lots of Photo's) that shows the seat posts being cut. Pretty good pics.
kprez007
Quote from: teddy037.2 on June 02, 2009, 02:18:36 PM
Was fine before the Chop.  With the signal brackets needed to remove the 2 posts.  But is fine.  Instructions said "Some Models may need to cut down seat."
herm
someone should add to their HOW TO: tail chop...
washers to lift the seat latch mechanism take care of this problem.
No more Monster.
kprez007
Here are the before & after pics of the Tail Chop using the Competition Werks Eliminator Kit.
booger
Quote from: rosejay0918 on July 01, 2009, 12:22:56 AM
Some of the critics are the washers to lift the seat latch mechanism take care of this problem.It will takes for Tail Chop
LOL - WTF
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Spammer with a link in their post, trying to bump up their site by riding on our coattails.
alexisonfire
I installed the CW tail chop kit a few weeks ago.  My seat didn't have posts underneath it but when connecting the seat to the bike there was some intereference between the seat's rear edge and the top of the tail light that wouldn't allow the seat to go down far enough to hook into the latching mechanism.  Unscrew the two bolts holding the seat latching mechanism to the bike and place some washers between it and the frame.  Problem solved, no difficulty latching and the seat is elevated enough such that the cowl doesn't rest on the turn signals (bending them downwards).  I couldn't tell you if the washer method works for seats with posts.
You can live to 100 if you give up all the things that make you want to live to 100.
07 S2R 1000
