January 10, 2025, 07:09:58 PM *
Author Topic: New member.... Some pics of my 696  (Read 2229 times)
DoWorkSon
« on: June 03, 2009, 12:44:07 PM »
Hello all.... New member here.... Been posting on another forum for awhile, but this board seems to have the most active members, and most people posting and replying.... Just thought I would share my 09' 696... My friends and I love doing custom projects and have done a few to this bike including a custom oil cooler($100 vs the $400 DP oil cooler), and new headlight(hate the stock headlight, looks like a giant glass bowl on the front of the bike)... Other mods are
- 14t front sprocket
- KN air filter
- Quat D exhaust
- Speedymoto frame/fork/barend sliders
- Bar end mirrors
- CW tail chop
- Barracuda moto windscreen
- Removed charcoal canister and shroud
- Removed "monster decal"
and some other little touches....
Waiting on touring seat and Power Commander V whenever they decide to release it.... hope you like
2009 M696--SOLD
Online Online
Feral 859
« Reply #1 on: June 03, 2009, 01:03:09 PM »
Nice. Pretty slick windscreen.  waytogo
dutchy73
« Reply #2 on: June 03, 2009, 10:14:56 PM »
Have a write up on the headlight mod?
'09 696 Dark, Termi, Rizoma, CRG
DoWorkSon
« Reply #3 on: June 04, 2009, 01:29:58 AM »
Have not written a detailed one yet, but here is the basics
I purchased the headlight, brackets, and turn signals from xpostreetfighter.com... Was a package deal with everything.
Step 1:
Removed old headlight and gauge. The problem with the 696 is that the gauge sits directly into the headlight bracket. So, by removing the headlight, you have taken away the mount for the gauge. Before I could even think about putting on a new headlight, I had to figure out a way of mounting the gauge to the bikes. I solved this by using pre-threaded holes already under the handlebars which the stock headlight had mounted into.
I purchased some aluminum metal strips(about 2 feet long, and 1" wide) from Home depot, cut them into two, approx. 4" long pieces, and bent them into a semi "S" shape(almost like a lightening bolt shape). underneath the handlebars, there are two threaded holes where the stock headlight mounted(on the underside of the steering head). I drilled holes into the metal strips and using the existing bolts, some rubber grommets(vibration dampening) and washers, I mounted the metal strips.  I then drilled a hole at the other end of the metal strips, and this is where the gauge was attached using the stock bolts, some more rubber grommets, and washers. To mount the gauge to the strips, simply remove the plastic back of the gauge, and use the existing holes.
The trickiest part was getting the angle just right on the metal strips. I used a vice and rubber malot to bend them at the correct angle, so when sitting on the bike, the gauge was clearly visible and at the right height and angle. Secondly, the windscreen that i have sits behind the gauge, and covers these mounts, so you cannot see them. Without the windscreen that I have, the mounts would be visible and I do not think it would look good.
Once I was able to mount the gauge, I had to install the light...
Step 2:
The connectors on the stock headlight were cut off, and attached to the new headlight. The new headlight was plugged in to make sure everything worked.
I then mounted the brackets given to me with the headlight. The problem with these brackets is that they were way way too long. Using them would cause the headlight to stick out about 5" and would just look funny. So, I cut these down using a dremel, drilled holes in them for the turn signals to mount to, bolted everything up, and made sure everything was at the correct angle, height and position I liked. I then sent the brackets in for powder coating. Once the parts were done at the powder coater, I mounted it all up, and it worked like a charm.
I do not have pics of the install.... But will get some pics of how everything is mounted up It's difficult to explain how we mounted everything up, but pictures would make it pretty clear. It was a lengthy process of trial and error getting the brackets and mounts to line up correctly, but well worth it IMO.
I also have a DIY oil cooler write up if anyone is interested.
2009 M696--SOLD
dutchy73
« Reply #4 on: June 04, 2009, 05:59:00 AM »
Nice work. Looking forward to some pics. I am thinking about swapping out the headlight on my bike, but have been holding off because I know how involved it was going to be. Especially because of the gauge mounting issues. But this helps a lot in terms of confidence. Glad that I now know it's possible and not entirely that difficult.
DoWorkSon
« Reply #5 on: June 04, 2009, 10:28:36 AM »
It really was not that difficult, especially if you have the tools to cut/drill/bend metal. Like I said, it was mainly trial and error just getting everything in the right position, angle and height. The basic tools I recommend are a bench vise, hacksaw or dremel w/heavy duty cutting wheel, malot, and a step bit for drilling new holes..... Then just take your time and use your imagination... Pics will be coming soon once I have a digital camera available
2009 M696--SOLD
