February 04, 2025, 10:06:37 PM
Will this fit on a M900
Topic: Will this fit on a M900 (Read 4099 times)
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
June 04, 2009, 10:10:30 AM »
I've been needing a new one of these for my 97 M900. Will this work?
http://cgi.ebay.com/ebaymotors/02-DUCATI-620-MONSTER-600-COOLANT-BOTTLE_W0QQitemZ370199314461QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item563199401d&_trksid=p4506.c0.m245&_trkparms=65%3A12%7C39%3A1%7C72%3A1171%7C240%3A1318
Quote from: bobspapa on July 18, 2009, 03:40:31 PM
Omnipotent Potentate
Personal Pretext
Re: Will this fit on a M900
June 04, 2009, 10:56:26 AM »
If it is from a 620 - no. They are a different shape. Also... there's no coolant bottles for 900s or 620s - don't know what that sellers on about. That's part of the crankcase breather set up...
Porsche Monkey
JuddDdd likes my
June 04, 2009, 11:49:08 AM »
Are you sure? Its advertised as a coolant bottle. Mines cracked and leaking some sort of fluid.
Last Edit: June 04, 2009, 11:52:11 AM by Ducaholic
June 04, 2009, 11:54:39 AM »
Seriously, it wont fit.
Even if you try and use it as a crankcase breather.
Jokingly, make sure he throws in the prudpusperator valve, you'll need that too.
Without it, your muffler bearings will spin backwards, and we all know how badly that goes.
Porsche Monkey
JuddDdd likes my
June 04, 2009, 11:55:59 AM »
Huh?
Personal Pretext
June 04, 2009, 11:57:51 AM »
He's messing with you. It's a blinker fluid reservoir.
And yes, we are sure it will not properly fit.
June 04, 2009, 11:58:17 AM »
Quote from: Ducaholic on June 04, 2009, 11:55:59 AM
Huh?
Were you poking fun at the ad?
Porsche Monkey
JuddDdd likes my
June 04, 2009, 12:05:25 PM »
No I wasn't. Seriously the dealer wants like $200 bucks for this thing and I would much rather get the one on Ebay.
June 04, 2009, 12:10:30 PM »
Quote from: Ducaholic on June 04, 2009, 12:05:25 PM
OK.
You may find one in the classifieds.
Or, shoot m9hundo a PM, he's likely got one.
Personal Pretext
June 04, 2009, 06:01:24 PM »
Or you can ditch it and go with a K&N filter right on the breather. You loose some hoses and that box. You need to plug the hole in the airbox where the other end of that box leads too as part of the job.
TPO Parts
sells a kit.
That box just catches vapor from the crankcase breather. The leaking fluid only matters in that it means some un filtered air can get in though the breach and then into the case. That fluid's probably just a mix of oil and condensed water vapor.
Porsche Monkey
JuddDdd likes my
June 05, 2009, 06:20:07 AM »
Yeah I was just messin with y'all. My bad.
Jon
June 06, 2009, 02:23:18 AM »
i just cut mine up last week, could of donated it to you if you posted this earlier.
i cut my box up, fused the two nipples together then conneted the two tubed together.
Last Edit: June 06, 2009, 09:40:11 AM by He Man
Grrrly
Industrial Grrrl
June 06, 2009, 04:56:59 AM »
ducaholic,
here's a coolant bottle for ya!
The Evil Twins:
Urban Assault Vehicle:
2002 Duc M 6/900 Industrial Edition
Track Weapons:
2004 Suzuki SV650
2009 Kawi ZX-6R Monster Edition
schtirlitz
Evil DUC
July 31, 2009, 11:58:50 AM »
Quote from: yuu on June 04, 2009, 06:01:24 PM
TPO Parts
sells a kit.
Hey, i ve heard of a lot of people doing this... installing a filter on top of the breather and completely ditching "the box" and hoses. What are the impacts of this mod. I mean the filer would have to replaced every so often, right? Also what happens to all of the material (i don't know... hmmm, oil, vapor, etc) that goes through the breather? Any other thoughts on this?
Thanks!
Gun Control, means using both hands...
2008 Ducati S2R 1000 (R.I.P.)
2006 Paul Smart 1000 LE (DP ECU+AB / Termi 2-2 / Rizoma Rezervoirs / Oberon Clutch Cyl)
Personal Pretext
Reply #14 on:
July 31, 2009, 12:06:31 PM »
Well the filters from K&n have a one MILLION mile warranty... You do need to clean them on occasion, but unless something crappy happens you don't need to replace it.
A potential down side is that if you wheely a lot you might get some of the over flow coming out that filter. But under normal circumstances only air, water vapor and nominal amount of oil vapor will come out.
