January 10, 2025, 01:13:36 PM *
Pages: [1] 2   Go Down
Author Topic: monster still wont start  (Read 2655 times)
championmvp
TWO WHEELS ONE LOVE
« on: June 06, 2009, 04:03:49 AM »
alright over a month later this bike still wont start.i took it to x-it cycles in league city tx,an eximport guy cleaned the carbs and said it was ready to go.i pick it up and it wont start. so then it take it bob lunsford honda-ducati leave it three days, pick it up and it runs normally.later that night it wont start.i almost get stranded ,get it going and this morning it turns over wont fire up. wtf.ill be calling that shop when they open.they told me the compression was 130 and 150.anybody have any ideas? this is from my original post ....just bought an 01 monster 600,been riding it for three days.i have no idea why it keeps dying.its happened three times all on the freeway going uphill at about 70 mph.last night i had to call a wrecker and i still cant get it started.oil and everything else seems to be adequate.the bike was serviced a year ago and only 200 hundred miles put on since(oil change,new battery,fuel filter,carb cleaned,spark plugs,chain and sprocket.looking at the service record,2 months and 50 miles later the monster wouldnt start.previous owner was charged 144.00 to adjust air mixter(dont know what mixter means or if its a typo).anybody have any ideas,it would be easy to go to a shop and let them screw me for a couple three hundred bucks,but after buying the bike id rather try to figure it out myself first.any help would be appreciated
every time i strap that helmet on im risking it all.and so be it. such is the life of a ridah.
« Reply #1 on: June 06, 2009, 05:16:25 AM »
Assuming the fuel system is now in tip top order your problem would be electrical and could be a whole host of things.  More information is needed before we can even help you try and sot out the problem.
How long are you riding before the bike dies?
Does the bike instantly stall, start bucking or run out of steam gradually?
Does the starter turn the engine over at normal speed?
If you wait long enough does it restart?  How long?
If the bike turns over well, does opening the fuel cap help?
What year is the bike?
What tools and meters do you have to work with?
Do you have any electrical knowledge/
Tigermeat
« Reply #2 on: June 06, 2009, 06:52:23 AM »
Definitely sounds electrical if the engine is just shutting down at freeway speeds.  Two things have direct shutdown capability - the kill switch and the kickstand switch.  Is there anything wrong or modded on the kickstand?  I would defininately bypass the kickstand switch to see if that helps. It's one thing you can probably do for $0.00
Bladecutter
« Reply #3 on: June 06, 2009, 09:50:32 AM »
At this point, I would recommend looking at the fuel pump, and the fuel lines between the tank and the pump, and the carbs.
Since the bike is dying under periods over high fuel demand, and then not starting back up, I would think its either the fuel pump can't keep up with the demand, or there is a fuel line that is damaged internally between the tank and the carbs, that is blocking the fuel flow under high demand situations.
BC.
championmvp
TWO WHEELS ONE LOVE
« Reply #4 on: June 07, 2009, 05:33:41 AM »
whats up guys,appreciate the info.had work so it took me a while to get back. i rode last night finally and once i finally get it  started and hot it cranks up with no problem.im positive it shoulldnt take me 6 or 7 times on the ignition to get it started.when the bike is cold the choke doesnt even work.im also getting some back firing when i first get it going.its an 01 m600 10700 miles.carbs cleaned again,new fuel filter new gas(it had been sitting for an entire winter)i ran down the fuel lines and theres no crimps.
championmvp
TWO WHEELS ONE LOVE
« Reply #5 on: June 07, 2009, 05:39:52 AM »
also the bike doesnt die when i open it up anymore.and would a k&n air filter possibly disturb air fuel ratio?i have limited motorcycle mech knowledge,but this thing is even stumping mechanics right now.i tried popping the fuel cap and theres no pressure build up in the tank.also i had the kill switch disabled.
« Reply #6 on: June 07, 2009, 07:14:43 AM »
Another question:  Does your bike run well when it runs?
A K&N filter won't have an effect, but an open air box will.  Even then it would not cause the problems you are having.  When you get stuck on the road, very quickly check if you have spark.  Pull a spark plug wire, insert a screwdriver into the spar wire boot and hold it about an eighth of an inch from ground.  Crank engine.  No spark? Electrical.  If you look on the right side of the engine you will see two plastic lines coming down from the carburetor float bowls.  Follow these up to the float bowls.  You will see an 8 mm screw on each bowl.  This is the drain.  Open it.  Fuel does not come out, you have a fuel supply problem; fuel pump, vacuum shut off, hoses.  Now pull the spark plugs.  If they are sooty, suspect sticking floats, too high a float level or other internal carb problems.
championmvp
TWO WHEELS ONE LOVE
« Reply #7 on: June 07, 2009, 07:40:56 AM »
thanx will do.when i get the bike running now it runs great,no problems.but when its cold i have a hell of a time getting it fired up.also the last time i took it in they were thinking new jet kit.they called back and said it didnt need it,just had trash in carbs. really appreciate it howie,and all other posters
« Last Edit: June 07, 2009, 07:48:39 AM by championmvp » Logged
« Reply #8 on: June 07, 2009, 12:22:42 PM »
If your bike has factory jetting poor cold running is to be expected.
championmvp
TWO WHEELS ONE LOVE
« Reply #9 on: June 08, 2009, 04:43:22 AM »
Alright could somebody give me an idea of what could possibly be affected by riding into strong head winds. I rode at 80 on the beltway for about 25 miles with no problem. When I jumped on last night and felt the wind stalling crossed my mind because it's happened before. And lo and behold it gradually stalls out. Felt like it was losing power or fuel. Started up 5 min later like nothing happened. Didn't check float bowl or spark,didn't have screw driver. But going into wind?
« Reply #10 on: June 08, 2009, 01:22:28 PM »
If you no longer have the grey pods on the sides of the bike, yes it is possible.  There are vent lines that go from the carbs to these pods.  The job of the pods is to provide calm air for the venting.  The good news is you don't need the pods, but the vent lines must be located in an area where the air is still.  Some experimentation may be needed.  There are also filters in these lines that can clog, though I've only heard of this happening once, on a Honda VFR.
championmvp
TWO WHEELS ONE LOVE
« Reply #11 on: June 08, 2009, 02:40:31 PM »
ill try it as sooon as i get off work.i was smart oe dumb enough to ride it to work anyway.erkishhorde also mentioned something about head winds,said he changed the fuel pump and wasnt positive that was the problem,then the thread ended without an update.
erkishhorde
« Reply #12 on: June 08, 2009, 03:19:38 PM »
Oh, sorry about that.
I had gotten a suggestion to check the grey pods like Howie mentioned and shrugged it off after I checked the one on the right and everything was fine. Problem was, I had an old hose that split and fell off the LEFT grey pod.  bang head Finally found that when I started pulling my air box to replace the fuel lines.
That helped the stalling out at speed a little bit but I still had fuel issues. Now, though, I ran into fuel issues where the bike would sputter out and die like it was out of gas randomly whenever I had more than 70mi (about 1/2 tank of gas) on the clock. Since I'd replaced/ rerouted nearly all the fuel lines and had replaced the fuel pump and filter within the last 4 months I decided that there was likely something floating in the tank. I've since dropped off my tank for a cleaning/ POR15 rust treatment as well as a valve adjustment (I was due anyway) and have not picked it up yet so I don't know if this will nail down my problem yet.
I have very high hopes but nothing is guaranteed. Oh, another factor that pointed me toward something floating in the tank was that my fuel issues would become more frequent when I more miles on the clock (less gas in the tank).
El Matador
Do I need knee pucks for my
« Reply #13 on: June 09, 2009, 12:45:30 AM »
Damn, I wish I would have seen this earlier. I'm in Houston, but I'm leaving on Wednesday for a week.
Post up in the local section, a guy named Hiero is basically the second coming of Jesus with a Torque Wrench when it comes to ducs. You should be able to get all the help you need.
If you haven't figured it out by the time I come back, i'd be more than willing to try and help.
championmvp
TWO WHEELS ONE LOVE
« Reply #14 on: June 09, 2009, 05:47:18 AM »
much appreciated.would that local be dfw or hill country?i also talked to the guys at the shop.they say it fires up everytime on starter fluid hmmm.my receipt also says starts better with choke off.better? they were paid to make it start correctly bang head thats my second carb cleaning in two weeks Angry
Pages: [1] 2   Go Up
