September 29, 2024, 08:17:51 AM
800 s2r udder eliminators - which brand does not use stock headpipes?
Topic: 800 s2r udder eliminators - which brand does not use stock headpipes? (Read 2378 times)
cobrajet
June 08, 2009, 05:05:57 AM »
All of the cat eliminator pipes of have seen advertised for 800 S2R's seem to utilize the original headpipe portion of the system but I have seen several pictures where the cat section has been replaced with pipes going all the way to the heads in one piece. What brand are those? Comments on pros and cons? thanks, bill
psycledelic
Re: 800 s2r udder eliminators - which brand does not use stock headpipes?
June 08, 2009, 11:28:39 AM »
Mine came from Ducati Performance, which, if I am not mistaken, is made my Termignoni. They ran straight from the heads back to the slip ons.
06 S2R800 - the wife
04 999s - the mistress
rockaduc
June 08, 2009, 01:35:13 PM »
+1 on the Termis. I think the Zards replace the stock header on the horizontal head, but use the stock piece fo rthe vertical head.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
cobrajet
June 08, 2009, 01:42:18 PM »
Thanks, that is the one I was seeing, bill.
CairnsDuc
June 08, 2009, 02:23:30 PM »
Quote from: psycledelic on June 08, 2009, 11:28:39 AM
+1 I have the same fitted on my S2R 800, Same as pictured above
psycledelic
June 08, 2009, 03:10:22 PM »
I think you will be happy with the looks. It kind of gives a squared off visual line t the motor. Doesn't drop down lower then the oil filter like most aftermarkets.
JTMOTO
June 11, 2009, 12:18:12 PM »
This is what I have. Looks very similar to psycledelics
http://www.motovationusa.com/mvstore/Scripts/prodView.asp?idproduct=286
corey
'06 Tang/Black S2R800
June 11, 2009, 01:01:19 PM »
Quote from: rockaduc on June 08, 2009, 01:35:13 PM
Nope. Zards use both stock header pipes.
Not an easy install at all :/
cobrajet
June 23, 2009, 08:01:35 AM »
Where can I buy the Termignoni piece without buying a complete system? Can't find a listing anywhere, thanks.
krista
... does she have a
ducati addict
June 24, 2009, 03:20:45 PM »
We offer the Remus brand and their full systems go all the way to the heads. I am very impressed with the look of their L+R GP full system. That was the first time I have ever seen hi pipes on a Monster and immediately thought they looked awesome.
The S*R family of monsters definitely have created a great amount of confusion about which parts go where; expect very little compatibility between brands.
Chris
Krista Kelley
autist formerly known as chris
official nerd for
ca-cycleworks.com
