April 27, 2024, 11:14:26 AM
ungeheuer 696 - featuring ceramic coated exhaust, speedymoto tallboys..
Topic: ungeheuer 696 - featuring ceramic coated exhaust, speedymoto tallboys.. (Read 32677 times)
DucinKtown
Re: ungeheuer 696 mods - now with new Rizoma rear-sets & timing belt covers...
Reply #30 on:
July 18, 2009, 05:19:54 AM »
That looks sick, love it!!!
How is the handle bar position for you? Did you have to adjust the turn lock outs?
That is one clean 696.
Thanks Russ
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #31 on:
July 18, 2009, 05:55:00 AM »
Thanks
DucinKtown
I backed the steering lock bolts out by around 2mm each side.
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
nikkimonster
Reply #32 on:
July 18, 2009, 06:30:19 AM »
nicest mod ive seen. great job.
jborders5
Re: ungeheuer 696 mod pix - now with Rizoma rear-sets & timing belt covers...
Reply #33 on:
July 25, 2009, 03:12:41 PM »
Quote from: ungeheuer on July 18, 2009, 04:56:21 AM
Rizoma rear sets
Along with cool new Rizoma timing belt covers, rear brake reservoir, oil filler-cap and RyanRacer edition Ti tank bolts. I also lowered the instument binnacle by around 12mm to pull it in tighter to the top-triple.
Looking good! Any tips and/or pics on how you lowered the instruments closer to the headlight & top triple? Thanks.
danaid
Re: ungeheuer 696 mod pix - featuring Rizoma rear-sets & timing belt covers...
Reply #34 on:
July 25, 2009, 09:52:50 PM »
Awesome job!
Now you need some new pimp-in wheels.
11' 1198SP Black
09' 1100S Red
09' 696. Red first Ducati (sold)
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #35 on:
July 27, 2009, 03:17:13 AM »
Quote from: nikkimonster on July 18, 2009, 06:30:19 AM
Quote from: danaid on July 25, 2009, 09:52:50 PM
Awesome job!
Quote from: jborders5 on July 25, 2009, 03:12:41 PM
Thanks for all the positive comments guys
Lowering the speedo binnacle is a little scary coz it's a one-way-mod... which involves cutting down the mounting arms - an integral part of the alloy headlight casting. I cut the mounting arms down by around 12mm and fabricated 2 new small brackets which live beneath the speedo cover out of sight. Not hard to do, but there's no going back. If you have now or intend ever to fit the micro-bikini fairing then I wouldnt recommend doing this. Also for me I felt I needed to do this as the speedo was sitting out further ahead after I fitted the speedymoto top-triple..... I dont know if there would be room to do it with the stock top-triple coz of the handlebar mounts...?
__________________
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Reply #36 on:
July 27, 2009, 07:55:01 AM »
had been thinking about that lowering thing. has anyone looked at lowering the whole headlight unit? i think if you put a spacer in between the top triple and the hanger for the headlight enough to lower the headlight where the lower mounting bolts are below the bottom triple, it might work. i think it's about a 2-3 inch drop.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #37 on:
July 27, 2009, 04:31:38 PM »
Raux, coz of the way the headlight mounts to my speedymoto top-triple I needed to mount the headlight slightly lower than stock, but its only lower by about 5mm. I think if you lowered the headlight as much as you're suggesting then you're gonna run into (literally) clearance issues with the front wheel when the forks hit compression.....
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
ɹǝʌO d∩ uıɐןɐɹʇsn∀
The Ungeheuer 696 Project is Complete
Reply #38 on:
August 20, 2009, 10:29:01 PM »
Thats it. I'm done. Yup. Seriously. Stop laughing, I am done.
My M696 is going away someplace else and will be replaced by an M1100S
Last Edit: February 07, 2011, 04:01:31 AM by ungeheuer
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
sfarchie
Re: ungeheuer 696 mod pix - The Ungeheuer 696 Mod Project is Complete!
Reply #39 on:
August 21, 2009, 01:46:31 PM »
Looks great! I'm stuck between the Swatts and Tallboys. Are your Tallboys about the same length as the stock bars or ...? I have CRG barend mirrors on my stock bars and I think they stick out way too wide. I wanted bars that were a little narrower, so I can lane split easier.
I also wanted something with a little more sweep back than the stock bars and it doesn't sound like the Tallboys will give me that.
I wonder if the Swatts would fit a 696/1100? I was told the Tallboys fit perfectly since they clamp to the sides of the forks.
Ray
SFaRChie
S2R 800 '07
Reply #40 on:
August 21, 2009, 02:16:07 PM »
I can't find the post, but I'm 99% sure someone has the Swatt clip ons on a 696. (maybe mrPlease?)
You'll need the spacers for the 696 coffin master cylinder(s).
If I remember correctly, there were no issues fitting the Swatts (don't quote me on that)
Holden
Sausage Creature
Reply #41 on:
August 21, 2009, 02:22:17 PM »
Quote from: stopintime on August 21, 2009, 02:16:07 PM
Hamsandwich.
He may have had to change the headlamp:
http://ducatimonsterforum.org/index.php?topic=18644.0
sfarchie
Reply #42 on:
August 21, 2009, 04:49:26 PM »
Thanks guys! Anthony Creek from Desmoworks said the Tallboys work for the 09 Monsters because it won't interfere with the headlight supports. It looks like hamsandwich did some work to make his swatt clipons work. I'll think about it to see if it's worth my time and money...
Ray
SFaRChie
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #43 on:
August 22, 2009, 05:38:31 AM »
Quote from: sfarchie on August 21, 2009, 01:46:31 PM
Looks great! I'm stuck between the Swatts and Tallboys. Are your Tallboys about the same length as the stock bars or ...? ...I also wanted something with a little more sweep back than the stock bars and it doesn't sound like the Tallboys will give me that.
Cheers. Tallboys ended up just slightly narrower than stock bars and I set mine 37mm lower than stock bars. Could've got more sweep-back than I did but would have needed to sacrifice more steering lock. I think Swatts will give more sweep back without losing so much steering lock. Coz I'm a glutten for punishment I have ordered me a set of Swatts and will fit 'em up to my incoming M1100 in the near future and then decide which I prefer.
Watch this thread for my progress (or lack of it
http://ducatimonsterforum.org/index.php?topic=21407.msg488629#msg488629
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Reply #44 on:
August 22, 2009, 09:44:50 AM »
what did you do with your stock front end stuff?
