January 10, 2025, 07:19:57 PM
DP Airfilter and Box worth it? Best place to buy? Before or after TPS reset?
Topic: DP Airfilter and Box worth it? Best place to buy? Before or after TPS reset? (Read 1812 times)
DucRulz
June 09, 2009, 02:21:26 PM »
Installed Akrapovic Exhaust and DP ECU, running like crap! Getting TPS reset ASAP, but my questions is: DP Airfilter and mod box a big bonus? Also if so, can I have the TPS reset and then get the airfilter/box and add it later with needing to get the bike tweaked again?
Not sure if I can have the box and filter here before I can have the TPS reset, if I need to have it before I guess I can wait then.
2007 S4RT Ti/red, Monstrack mirrors, 14T, CF Hugger, Akrapovic Ti Evo Exhaust
2006 H-D Nightrod, open pipes w/fuel manager
rockaduc
Re: DP Airfilter and Box worth it? Best place to buy? Before or after TPS reset?
June 09, 2009, 04:16:01 PM »
Quote from: DucRulz on June 09, 2009, 02:21:26 PM
After I installed my DP ecu, my bike wouldn't even start until the TPS was reset. The DP ecu was designed to run w/ an open airbox, high flow airfilter set up, so until you get those things, it will probably run rich. Once you install the open air box and high flow filter, you
should
be fine.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
teddy037.2
June 10, 2009, 08:22:06 AM »
+1
if your box is still stock, it's probably running pretty rich
:edit: instead of DP box, you can always cut yours
Last Edit: June 10, 2009, 08:28:09 AM by teddy037.2
Spain
'07 695, '13 1100 evo
June 10, 2009, 09:05:40 AM »
I have your answer:
http://ducatimonsterforum.org/index.php?topic=23975.0
DucRulz
June 10, 2009, 09:47:46 AM »
OK I will get a filter and airbox or cut mine, do I just trim the top with saws-all or dremmel? Probably a stupid question here, but there is that pad between my fuel tank and air box, that would also restrict airflow once I get a modded air box right (I would assume)? Do I just remove it, or modify it as well?
Yeah, I installed the ECU, turned key on, push ignition button and....NOTHING! Not even an attept to turn over. Turned off the key, waited then turned on, and she fired up, sick sounding but started. Is that delay a common thing at initial install ad first time key on?
Awesome help
Last Edit: June 10, 2009, 09:49:46 AM by DucRulz
pennyrobber
June 10, 2009, 10:03:09 AM »
I just cut a hole more or less on the top and front of the box that follows the lines of the box itself. (Think where the box starts to flatten out on top.) The dremel worked great. I left the pad under the tank as it really doesn't make a difference to the airflow with how big the hole is that I cut. Some people just cut smaller wholes in the box especially on the back of the box that would be restricted by the pad though.
June 10, 2009, 12:05:11 PM »
I would remove the pad since it won't be doing it's job anyway once the air box is cut.
Fresh Pants
Moof
June 10, 2009, 12:18:28 PM »
Step 1: cut a hole in that box.
No, but seriously. Isn't the DP part just a cut stock airbox lid?
The shop I took mine to cut the lid for me, so I can't recommend techiniques other than what's already been mentioned here. I have pics of it somewhere...
Bwooooooahhh
Braaaaaaaappp
teddy037.2
June 10, 2009, 01:23:53 PM »
Quote from: Fresh Pants on June 10, 2009, 12:18:28 PM
bahahahahaha!!!!
DP lid, from the looks of it, is exactly that
I used a dremel, the sanded down all the melty bits... still have that foamy pad in there, though
I guess I couldn't be buggered to take it off
