August 18, 2022, 12:34:24 AM
FAQs and Board Policies
FAQ: Model Comparison -- Different Monster Generations
Topic: FAQ: Model Comparison -- Different Monster Generations (Read 19442 times)
Spidey
Crashin' mofo
June 10, 2009, 01:18:21 PM »
The following is a summary of the different generations of monsters.
This FAQ is a work in progress.
I'll add more info as time permits. Feel free to contribute about specific model years, features, etc.
Current generation ('09)
: 696/1100.
696
-- half trellis frame, DSS, wet clutch, radial calipers, 696cc air cooled engine, dual-sided high mount exhaust.
796
-- half trellis frame, SSS, wet clutch, radial calipers, 803cc air cooled engine, dual-sided high mount exhaust, optional ABS.
1100
-- half trellis frame, SSS, 1100 dual spark engine, air cooled, dry clutch, dual-sided high mount exhaust, radial calipers.
Streetfigher
-- though not technically a monster, it replaces the S4rt and s4rs. A naked beast with a 1098 engine.
S*R Generation ('06-08)
: the S*R line (with the 695 as the 'classic' styled monster)
S2r or S2R 800
(05?-08)-- ST based frame, single sided swingarm, 800cc engine, wet clutch, air cooled, one-sided shotgun exhaust.
S2r 1000
(06-08) -- ST based frame, SSS, dry clutch, 1000 dual spark motor, air cooled, one-sided shotgun exhaust. Replaced by M1100
S4RS/S4Rt
(07-08) -- ST based frame, SSS, 999 testastretta motor, dry clutch, radial brakes, water cooled, one-sided shotgun exhaust. Replaced by Streetfighter
S4R
(04-06) -- The first of the S*R monsters, and sold at the same time as the ST-based DSS generation. ST based frame, single sided swingarm, 996 water cooled motor, dry clutch, one-sided shotgun exhaust. Replaced by the upgraded s4rs/s4rt with the 999 motor.
695
-- ST-based frame, DSS, wet clutch, 695 cc motor, air cooled, dual sided low-mount exhaust. Basically, it was a 620 with a bigger motor. Has the look of the "classic" DSS monster. Replaced by M696.
ST-based DSS Generation ('02-'05)
-- "Classic(?)" monsters
M1000 ('03-'05). St-based frame, DSS, 992cc dual spark engine, air cooled, dual sided low-mount exhaust, dry clutch. Replaced by S2r 1000.
M800
('03-'04). ST based frame, 800cc engine, DSS, air cooled, dual sided low-mount exhaust, wet clutch. Replaced by S2r (also called S2r 800).
M620
('02-'05). ST based frame, 620cc, DSS, air cooled, dual sided low-mount exhaust, wet clutch. Replaced by the 695.
S4 or MS4
('01-'02). The '01 S4 was the first ST-based monster. ST-based frame, 916 water cooled engine, DSS, dual sided low-mount exhaust, dry clutch. Replaced by s4r.
M750/M900. St-based framed, fuel injected 900s and 750s were availabe in 2002.
888-based DSS Generation ('93-'01)
Note
: You can idenitfy the 888-based monsters by the hoop over the swingarm.
M600
('01 in US): 888 based frame, DSS, wet clutch, single front brake rotor, carb'd 600cc motor, dual sided low-mount exhaust, air cooled. Replaced by M620.
M750
('97-'01): 888-based frame, DSS, wet clutch, single front brake rotor, carb'd 750cc motor, dual sided low-mount exhaust, air cooled. Replaced by the M800. Note: some of the later 750 models have an oil cooler (2000-'01 and maybe earlier models) and the '01 has dual front disks.
M900
(93-'01): 888-based frame, DSS, dry clutch, 900cc engine, carb'd until 99 and
i.e.
(fuel injection) from 2000-02, dual sided low-mount exhaust, air cooled. Replaced by the M1000.
Note: The M400 is a Japanese-only model.
DSS = Dual sided swingarm
SSS = Single sided swingarm
Last Edit: May 07, 2010, 06:55:20 AM by Spidey
loves ze desmodromics.
Re: FAQ: Model Comparison -- Different Monster Generations
June 11, 2009, 05:32:56 AM »
This is pretty much exactly as I see it. All DSS Monsters - 400/600/620/695/750/800/900/1000/S4 are the Classic Monsters. If it looks like the '93 M900, it is a classic. Sure the frame changed, and the motors changed, but the shapes are the same.
The Single Sided Swingarm was not a dramatic change to the look, but coupled with the different exhaust, there is no confusing it with a standard "classic Monster".
Then you have the newest generation, which might be called the "modernized" or whatever.
Spidey
Crashin' mofo
June 12, 2009, 09:55:58 AM »
Current Generation -- Examples
M696
M1100
S*R Generation -- Examples
S4Rs
S2r 1000
M695
Note: This bike is technically a part of the prior generation of DSS, ST-based frames, but it was sold at the same time as teh S*R generation.
ST-based DSS Generation -- Examples
S4
M620
888-based DSS Generation -- Examples
M750
(Note the hoop over the rear swingarm)
Last Edit: June 12, 2009, 04:17:47 PM by Spidey
June 12, 2009, 03:19:18 PM »
*need to edit example of 696 picture. it shows an 1100 with sss and dry clutch. looks like they be switched.
Spidey
Crashin' mofo
June 12, 2009, 04:17:03 PM »
Oops.
Gracias.
jdupont4
February 19, 2010, 07:58:54 AM »
I think the discription of the m750 may be a little off. the m750 (at least the 2001) has an oil cooler and dual front rotors
Spidey
Crashin' mofo
February 19, 2010, 08:10:00 AM »
Good catch. It looks like some earlier 750 models (at least the 2000 as well) have an oil cooler. I'll edit accordingly.
Jaman
April 19, 2010, 06:55:52 AM »
