Safety Wire Question
Started by Fast Cletus, May 19, 2008, 02:23:02 PM
Fast Cletus
I am particpating in my first CCS race this weekend, and I have a questions regarding what to safety wire so I will pass tech.  Here is what I know I need to safety wire, Oil Filter, Oil Filler Cap, rear pegs.  Do I need to saftey wire the calipers front and rear and also the rod that goes through the back wheel?
I posted this on the DML, but after reading spidey's message I guess we are all jumping ship?
Jimmy C
aka Fast Cletus aka Suthrnr
PS I am racing my monster
2001 Monster Dark 600cc
2001 Supersport 900cc
CCS Racer #552
gm2
Like this is the racing, no?
Fast Cletus
CCS Racer #552
derby
axles or axle nuts
oil filler caps
kickstarter retaining bolts
axle caps and/or pinch bolts
oil drain plug(s)
removable exhaust baffles
brake caliper bolts
oil gallery plugs
radiator caps
brake torque arms
oil lines
coolant drains
speedo and tach cables
spin on oil filters/filter bolts
any pressure fed lubricant line
fork oil drain screws/bolts
rear exhaust mount(s) (all)
-- derby
'07 Suz GSX-R750
duckwrench13
Some bolts may be a bit difficult to get to... recessed caliper bolts, etc... so you may need to use a blob of RTV, or E6000, silicone adhesive to secure them. It's flexible enough to resist vibrations, but strong enough to keep things in place. And you can remove it with a small pick and a good tug.
Of all the things I've lost, I miss my mind the most.
Gettin' blow'd up sucks!
Combat Veteran, Operation Enduring Freedom, Afghanistan 2006-2007
Ducatista
Quote from: Fast Cletus on May 19, 2008, 02:23:02 PM
I've always wondered what it would be like to have a Monster on the track, especially the little ones.
You might want to check around in your area for people who do safety wiring.  There are plenty of individuals who are not associated with shops who have safety wired so many bikes on their own that they will do it for a fee for other racers.
Congrats on racing CCS!  My boyfriend, Stillie, is racing CCS this weekend at Summit Point.  It will be a couple of years before I want to race, but it's gonna happen at some point!
carbon fiber Superbike front fender, bar end mirrors, floating cast iron rotors, carbon fiber chin fairing, Cycle Cat frame sliders, Arrow carbon fiber low mount slip ons, Rizoma billet cam belt covers w/ plexi windows, Rizoma billet front sprocket cover, billet handlebar clamp, carbon fiber rear hugger, tail chop, open air box, Corbin seat, stainless clutch springs w/ black keepers, suicideless sidestand bolt, Evoluzione clutch slave cylinder
www.myspace.com/bitgoddess
fasterblkduc
Quote from: duckwrench13 on May 19, 2008, 09:16:02 PM
That will not pass tech. Sorry man but that's the wrong advice to give someone on the way to the track. If that were acceptable then everyone would just use silicone or threadlocker on everything. You will get booted out of Tech. inspection very quickly if you try this.
If you have a recessed bolt head, first grind a flat spot on the outer diameter of the bolt head. Then drill through your flat spot. Put the bolt back into it's place. Torque it down. Now you will have a gap that's big enough to fit your wire through since you ground a flat spot.
I'll add another to the list. On my Monster, I also safety wire the rear axle adjuster bolts. It's easy and gives you something to wire your axle nuts to.
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
duckwrench13
Quote from: fasterblkduc on May 20, 2008, 11:26:20 AM
I've used this method on several of the bikes I built while competing in WERA/CCS with the Mototek Aprilia team, in 2003. I've also had to use it on some of the more difficult to access bolts on bikes I've run with Munroe Motor's AMA & AFM teams 2004-2005. Even this past weekend, there were some bolts that were done this way on the 749R that Tigre ran at the Infineon round of AMA. Not once has it ever become an issue with tech.
I'm not saying that it is a complete substitute for safety wire, but there will be instances where you cannot get adequate access to properly wire a bolt. It's in a situation like this, that a silicone adhesive is used.
fasterblkduc
#8
 :o  Wow!...I stand corrected. I'm surprised to hear that. I've only raced with one organization and the one time I did that method, I was hassled big time. They let me race that weekend but did not like it.  My appologies!  ;)
You mentioned caliper bolts...do they really let those go that way? I'm really shocked at that one. That's not difficult at all to wire.
Atomic Racing
2010 partners:
DucHead
I have a related question, so I resurrected this thread.
Does anyone have a link to directions for safety wiring?
I'm taking the Cornerspeed class at VIR in July, and they require safety wiring the oil fill cap, oil drain plug, and oil filter.
Here's an aircraft-oriented one:
http://www.avweb.com/news/maint/191176-1.html
The freshly cut end of safety wire is perfect for puncturing fingers.
Consider yourself skilled if you can safety wire four things without drawing blood.  ;D
DucHead
#11
Thanks Speeddog  :)  Looks straightforward...not necessarily easy, but straightforward.   ;D
But given the shape of the Ducati oil drain plug, how the hell do you drill it?   ???
Nevermind - I can purchase pre-drilled plug and filler cap here.
derby
-- derby
'07 Suz GSX-R750
DucHead
