local board index??
Started by Randimus Maximus, June 10, 2009, 10:03:20 PM
Randimus Maximus
if you are in one of the local boards, and click on the "local boards" link above the post area, it takes you back to the DMF home page, not to the Local Club Boards index area.
I hope that makes sense.  PM me if you have questions.
Yes, the "Local Boards" breadcrumb links to http://ducatimonsterforum.org/index.php#6
when the "Local Club Boards" on the sidebar links correctly to http://ducatimonsterforum.org/index.php?action=forum#6
Quote from: Randimus Maximus on June 10, 2009, 10:03:20 PM
It's a bug in the simple portal software.
Randimus Maximus
Quote from: ducpainter on June 10, 2009, 10:09:23 PM
can it be fixed?  easily that is?
not that it is a big deal, but more of a PITA.
Quote from: Randimus Maximus on June 10, 2009, 10:28:13 PM
As a workaround you can use the "Local Club Boards" link in the left sidebar.
Randimus Maximus
Quote from: somegirl on June 10, 2009, 10:34:26 PM
that's what I do, but I'm lazy at times.  :P
There is a fix, but it requires a modification to a php file that may cause upgrade problems in the future.
There is a new version of simple portal out, and as soon as things settle a bit we'll discuss upgrading to see if they have fixed the problem.
