Beating a dead horse - average temp of your bike ?
Started by ProTeal55, June 11, 2009, 08:26:03 AM
ProTeal55
#15
If I richenup the FATDUC from where it is now the bike starts to pop on decell and in-between shifts. So it seems to be in a "happy place" where it is currently. Next time I get to ride it (rain) I will slowly fatten it up to see what happenes..
Member: Half Fast Chicago
Website:
Bike: '01 900
Mods: 944 hi-comp pistons, pods, PCIII, Conti replica pipes.
In normal use (average 75 degree day, long ride) mine hits around 285 in town, or about 220 on the highway.
Short 20 minute ride to work, barely gets above 180
Hit 300 when I was stuck in the traffic leading to the motoGP. 90+ degrees, stop and go traffic.
Mike_D
Bike: 08 S2R1K
Mods: Full Arrow Exhaust with Fat Duc set on the lean side of half.
Normal running temp is about 220-230.  I got stuck in traffic on slab recently though and the temp climbed to 299.  I got a little worried so I pulled over and shut it off for about 15 mins.
2008 S2R 1k.  Black.  Pazzo Levers, 14 t front sprocket, CRG Hindsight LS mirrors, Cycle Cat Frame Sliders,  Oberon open clutch cover and gold/black EVR pressure plate, full Arrow exhaust with reflashed and mapped ECU, tail chop with gold Rizoma Avio 21 turn signals, Ohlins rear shock and Rizoma fluid reservoirs.
ProTeal55
#18
Well after doing some riding around tonight it seems as if the slip joints on the rear cylinder (on the BoomTubes) is leaking air.
I am guessing thise could def. be causing my bike to run hotter than normal (exhaust leaks are never a good thing)..
Looks like I need to pickup some high temp rtv/gasket stuff and seal all the slip joints up and then see how the thing runs..
[bang]
Website:
2006 S2R1K
Open air box
Termi full system
DP ecu
200-220
I usually ride very early (around 6am) and am home by noon or earlier
If I'm out on an 80+ day it will get in the 230's.
killerniceguy
Marving mid pipe
leovince Ti pipe
cut air box
PCIII 70hp on dyno
Running a 50/50 mix of VP C12 and 91 octane pump gas
On the track pushing it to the max with ambient air around 77F I get up to 230F.  Before PCIII, C12, midpipe on the track I have seen high 290's.
S2R800 race bike.  www.ducaticup.com
