January 26, 2025, 01:48:04 PM
Cost to powder coat?
Topic: Cost to powder coat? (Read 6891 times)
dlearl476
Re: Cost to powder coat?
Reply #15 on:
June 19, 2009, 11:05:05 AM »
Quote from: jfisher2 on June 17, 2009, 04:35:41 PM
had my frame sand blasted for $25 at a local big rig paint shop...then powder coated for $90 at R Spoor Coatings in Endicott, NY.
All that's left is to do something with that unsightly pipe.
jfisher2
Reply #16 on:
June 20, 2009, 06:56:05 AM »
Quote from: dlearl476 on June 19, 2009, 11:05:05 AM
you're definitely right about doing something with the pipe....although that's certainly not 'all' that's left to do...
97 M900
dlearl476
Reply #17 on:
June 20, 2009, 07:03:42 AM »
Quote from: jfisher2 on June 20, 2009, 06:56:05 AM
You have a good point.
RavnMonster
05 S4R
Reply #18 on:
June 20, 2009, 07:34:05 AM »
Powder coating can be pricey, but if you have the shop space you can do it yourself and maybe make a few bucks powder coating for other folks too. It not hard to do but you need an old oven. Do not use your wife's oven it will ruin it.
Eastwood sells powder coating kits you can get a whole starter kit with colors for under $200. Then go to a thrift store and pick up an old oven and you are in business. The problem is having the shop space to do it.
http://www.eastwood.com/hotcoat-powder-coating.html
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
-- Eleanor Roosevelt, First Lady of the United States, 1945
damianS4RS
Reply #19 on:
June 21, 2009, 05:14:55 PM »
Quote from: lazarus7 on June 17, 2009, 03:21:51 PM
damien, im in the tampa/ sarasota area,
and used
www.paradisepowdercoating.com
, local shop
talk to larry, see how backed up they are....
did passenger and operator rearsets/ pillions and a few small odds and ends for their minimum set-up price of $96....
came out perfect.
Thanks man, I'll check them out.
For $50 you can touch my
Reply #20 on:
June 21, 2009, 05:58:44 PM »
Quote from: RavnMonster on June 20, 2009, 07:34:05 AM
Some of the locals are less than impressed with the eastwood kit.
http://ducatimonsterforum.org/index.php?topic=25586.0
Reply #21 on:
June 21, 2009, 06:23:52 PM »
if you're going to buy a hobby gun. Go with HF unit. These started guns are fine for SUPER light duty work. and work fine for very very thin powders on very simple objects. I tried doing a wheel with mine, it wont adhere to a 90 degree corner because the ionized particles push each other away. It also wont work with objects larger than a wheel. I think thats what might of ended up breaking the gun. I had my hand held down on the trigger for almost 3 whole minutes. Either way, i ended up only paying $120 bucks to get my wheels/swingarm/rearsets powder coated. And i still have enough powder and propane to powder 5 more sets of wheels 10 swingarms and more!
So I ended up dropping $300 bones on a brand new Hypersmooth pony 50kv adjustable gun and have plans for a larger gas oven that fits motorcycle frames!
RavnMonster
05 S4R
Reply #22 on:
June 22, 2009, 07:51:10 AM »
Quote from: MrIncredible on June 21, 2009, 05:58:44 PM
Interesting ive never read any reviews on this system. Good to know.
RavnMonster
05 S4R
Reply #23 on:
June 22, 2009, 08:00:32 AM »
I dug a little and found this article.
http://powdercoatingbeginners.blogspot.com/2008/09/powder-coating-equipment.html
Reply #24 on:
June 23, 2009, 03:16:15 AM »
Quote from: He Man on June 21, 2009, 06:23:52 PM
The corner issue is present with
all
powder guns. It's called the Faraday cage effect. It's a technique thing. Read up on it.
