January 26, 2025, 01:51:54 PM
Please Help
Cost to powder coat?
Topic: Cost to powder coat? (Read 6892 times)
damianS4RS
June 11, 2009, 07:26:26 AM »
Hey guys,
I'm looking to take some parts off my bike and have them powder coated but I was wondering if you could give me a general idea of cost? Do they charge per piece? Is it cheaper if it's all one color? Do I have to do any prep work on the pieces? I want to do my rearsets, passenger pegs, headlight ring and bracket and if I could figure out how to, my triples as well. Also if you happen to know a good one in S. Florida, even better!
Thanks!
Cicero
Re: Cost to powder coat?
June 11, 2009, 07:32:06 AM »
Powder coaters generally price by how much of a rack you take up, and what color.
Often times with small parts and common colors (i.e. black) they have racks that are not quite full that they can add your pieces to for cheap.
Media blasting should be included in the price.
I had a clutch cover done in black for 20 bucks.
A swing arm in Ti gray was coated for 70. Find a recommended one, or have a small test piece done by an unknown place before buying a full or half rack.
hihhs
June 11, 2009, 07:50:48 AM »
I did both rearsets, kick stand, head light bezel, CW short tail, passenger pegs, & the weird wings that hold the passenger pegs, & the exhaust hangers all in black for $180. That seemed about right for where I live.
Monster 1100
ProTeal55
HalfFastChicago.Com
June 11, 2009, 07:59:00 AM »
Contact my Buddy Sean over at "The Powder Pro" --->
HTTP://WWW.THEPOWDERPRO.COM
He did all the coating on my Ducati (came out great).
Mention Half Fast CHicago and he will give ya deal
Member: Half Fast Chicago
Website:
pitbull
June 11, 2009, 10:42:01 AM »
I just had a frame and swingarm sandblasted and Powdercoated for $200
ab
ab
ab
June 11, 2009, 04:16:32 PM »
Quote from: hihhs on June 11, 2009, 07:50:48 AM
did that $$ include prep work ?
I think i got ripped off then.
620M 2004 Dark i.e.; ~ 57K miles (all me); Looking to swap out engine now.
Honda Grom 2015 ~ 3500miles so far. Love this lil bike
June 11, 2009, 04:49:12 PM »
depends a lot on where you live. they have to pay for rent/property tax too.
Over here in NYC, the cheapest i could find for prep/powder on ONE 5spoke wheel was $150.
Triple J
June 12, 2009, 08:27:02 AM »
I had a frame, 2 wheels, top and bottom triples, and a bunch of other smaller pieces coated (including media blasting and prep) for $350 here in Seattle. The frame was also a different color from everything else.
MotoCreations
June 12, 2009, 12:09:07 PM »
Make sure when you are comparing prices you are comparing process/labor involved.
I've had wheels/frames in the past which I had coated FIRST in a thinner "primer" process. Then the "color" process over the top of that. Result is smoother transitions on factory frame welds. (some shops do this as part of their "regular service" and billable -- some shops just coat as if it was an industrial fencepost in terms of quality finish desired)
Also I've had done THIRD coat overlays with light metallic in a clear powdercoat applied.
Other item is the cost of media used. If you are doing standard colors ala 100% gloss, that is pretty standard. But some of the shops I've used in the past will have a 65% gloss black or other oddball color combination available without having to special order media. (ie: they have it in stock)
Also remember with powdercoating, you can take a color sample to most good shops and they can forward to their supplier who have the matching spectroanalysis machines. Custom mix colors aren't that expensive to do. I think my worse bill was $55 to get an oddball gold color matched as well as a Ferrari red to perfection to other items already on the bike.
me:
www.MarkSavory.com
work:
www.MotoCreations.com
daily:
www.FaceBook.com
dlearl476
June 16, 2009, 09:12:20 AM »
Quote from: He Man on June 11, 2009, 04:49:12 PM
It also depends on the coater, and their overhead. Here in Vegas I can get wheels done at a really nice building for $150/ ea or in a shed for $40, and just about every price in between.
DrDesmo
June 16, 2009, 09:15:08 AM »
I had a grille on my volvo powdercoated for $20 bucks or so, including media blasting, it came out
SWEET
Adam
'95 916
'12 800XC
Rameses
*Your Mom* has a Hypermotard
June 16, 2009, 08:39:28 PM »
I had my rearsets, brake/shifter levers, passenger pegs and mounts, rear spring, rear suspension linkage, top and bottom triples, handlebar clamps, front fender mounts, and 2 heat shields done for $400.
The price included all prep work, even grinding down the casting lines on the triples and rearsets.
damianS4RS
June 17, 2009, 08:54:33 AM »
Thanks everyone for the info. Now all I need is a weekend of tropical thunderstorms and a bonus check and off to the powder coaters!
lazarus7
June 17, 2009, 03:21:51 PM »
damien, im in the tampa/ sarasota area,
and used
www.paradisepowdercoating.com
, local shop
talk to larry, see how backed up they are....
did passenger and operator rearsets/ pillions and a few small odds and ends for their minimum set-up price of $96....
came out perfect.
"...the greatest artists indulge in a 'culpable rivalry' with God." Stanislas Fumet
jfisher2
Reply #14 on:
June 17, 2009, 04:35:41 PM »
had my frame sand blasted for $25 at a local big rig paint shop...then powder coated for $90 at R Spoor Coatings in Endicott, NY.
97 M900
