January 07, 2025, 04:30:57 PM *
Author Topic: Tool Needed: Shock Spanner....  (Read 1897 times)
corey
'06 Tang/Black S2R800
« on: June 11, 2009, 12:05:31 PM »
Anyone have a source for me?
I need to pick up a spanner wrench for my rear shock on my S2R800.
I wanna goof around with preload a bit...
CairnsDuc
« Reply #1 on: June 11, 2009, 12:56:05 PM »
Check with the board Sponsors, a lot of those guys carry tools, If they don't have them, I know Monsterparts.com carries them.
rockaduc
« Reply #2 on: June 11, 2009, 01:14:09 PM »
Also try Bevel Heaven if you can't get it from a sponser.
Spidey
Crashin' mofo
« Reply #3 on: June 11, 2009, 01:15:09 PM »
This doesn't answer your question, but as an alternative to buying a specific tool, I've always used a hammer and punch (or screwdriver).  Unless your S2r has one of those newfangled plastic collars.
erkishhorde
« Reply #4 on: June 11, 2009, 02:43:37 PM »
I went with this method when I first got my bike. Be very patient and careful. It will bugger up any fancy finishes regardless but you can try to reduce this by putting a folded up rag under your screw driver. Also get the biggest flat head you can find.
Spidey
Crashin' mofo
« Reply #5 on: June 11, 2009, 03:07:05 PM »
Yeah, no matter how you do it, your shock collar gets a wee bit chewed up.  I've always assumed that any bike I have will have a dinged up shock collar.  It goes with the territory.  Then again, you shouldn't be setting preload more than a few times unless you make a habit of adjusting it for passengers (more work than it is worth IMO).
brimo
酒後吐真言
« Reply #6 on: June 11, 2009, 09:35:45 PM »
I just went in to my local tool supplier and bought an adjustable c spanner,they fit multiple sizes so you need to get a rough measurement of the diameter of the ring and go from there.
They look something like this.
http://brooksuspension.co.uk/shop/c-spanner-adjustable-p-413.html
From a story by RAT900
Tigermeat
« Reply #7 on: June 12, 2009, 01:21:58 AM »
Pro-Italia
Very Cheap.  Good service.  You need 2.
Tigermeat
« Reply #8 on: June 13, 2009, 01:40:24 AM »
If you grind the inside tang off 1 of the wrenches it still works okay as a backup wrench for the shock but also works for chain-cam adjustment.  Wrenches are about $9 each.
Statler
« Reply #9 on: June 13, 2009, 05:07:23 AM »
And even with a wrench the plastic collars get beaten up.
Last time I looked, motowheels has some in stock...but they aren't hard to find.
two is much easier than one.
