Alternative for clutch microswitch
Started by Spidey, May 05, 2008, 11:05:41 PM
Spidey
Has anyone found a cheap alternative to the Ducati OEM clutch master microswitch (Brembo goldlines if it matters)?  Is that a RadioShack part or do I need to go OEM?
Quote from: Warren on May 05, 2008, 11:05:41 PM
a switch is a switch.
No part#, but if you can determine if it's normally open or normally closed and can figure out a way to mount it there's no reason to go oem.
You're talking late-model goldlines (small pin) like your bike used to have?
DarkStaR
Some people just short the wires, and REMEMBER to pull the clutch when starting.
