January 10, 2025, 06:11:37 AM
How hot is too hot?
Topic: How hot is too hot? (Read 1284 times)
Ranger06
How hot is too hot?
June 13, 2009, 06:44:10 AM »
I know 695's run hot, especially here in NC in the summer. What temps do you guys regularly see? I recently hit about 270 on the highway headed to Raleigh. I'm not running an oil cooler, how much do they help? The stock cans are cored though, does that make a difference?
Thanks
2008 695 Dark
Re: How hot is too hot?
June 13, 2009, 10:12:28 AM »
Too hot, according to Ducati, is 338
o
. An oil cooler will significantly lower your temperature at speed, not so much in traffic. On a 695 your cored pipes will not make a difference.
crazy bike girl
aka msincredible
June 13, 2009, 10:51:44 AM »
I often run at 240-250F without issue.
photo FAQ
teddy037.2
June 13, 2009, 12:55:49 PM »
also, the dash display will change when the temp gets too high
and +1 on the oil cooler
Ranger06
June 13, 2009, 07:02:37 PM »
Thanks all. I guess the only reason I bring it up is because there is a little blistering right where the exhaust mates up. The tech pointed it out to me during my last service and said I was running way too hot. I think that was his pitch to justify selling me a DP computer...which I want, but don't have the cash for now
2008 695 Dark
June 13, 2009, 07:56:11 PM »
Quote from: Ranger06 on June 13, 2009, 07:02:37 PM
The DP ecu will also make a huge difference in running temperatures, plus you get a performance boost.
Scotzman
Now that's thinking with your
June 13, 2009, 08:49:20 PM »
In sunny San Diego I normally get to 250-260 after about 30 mins on the freeway, so....I don't know if the type of oil you're using will make any difference as well.
teddy037.2
June 14, 2009, 06:12:33 PM »
wasn't there a known issue w/the 695 heads having flaky paint?
I seem to recall that
Paegelow
June 14, 2009, 08:05:32 PM »
Not flaky, the paint melts and turns brown around the exhaust port. Mine did, I got new heads on warranty (!!!), and I added a Termi kit with the DP ECU. That helped but the paint melted again within a month!
