January 08, 2025, 01:44:32 PM *
Author Topic: and to pile on.....  (Read 1495 times)
vwboomer
« on: June 13, 2009, 05:11:28 PM »
to my radiator woes...I took the radiator off so I can take it to a shop and noticed what looked like diarrhea under my counter sprocket.
Pulled the cover off and found a little piece of rubber that looks suspiciously like it might be the seal for the front sprocket  bang head
How bads it leakin? I dunno. But I do know 2 weeks ago when I put the new slave cyl on there was no leak.
Is this a simple matter of yanking the sprocket and replacing the seal or is this a split the cases type deal?
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
Online Online
« Reply #1 on: June 13, 2009, 05:45:23 PM »
The countershaft seal can be changed without splitting the cases...
but are you sure it's not the dust boot for the slave?
vwboomer
« Reply #2 on: June 13, 2009, 06:18:44 PM »
There was no oil around the new slave. I cleaned up the case around the sprocket so we'll see. I did crank seals on my VW often enough it shouldn't be a problem if it's a leaker, just wanted to make sure it was an outside in job
2005 GasGas FSE450
2004 Honda VFR
Online Online
« Reply #3 on: June 13, 2009, 07:38:44 PM »
There doesn't really have to be leaking from the slave for the dust boot to deteriorate from chain lube.
Got a pic of this rubber piece?
vwboomer
« Reply #4 on: June 13, 2009, 08:37:01 PM »
obligatory crappy pic. Cell phone is all I've got
2005 GasGas FSE450
2004 Honda VFR
aaronb
« Reply #5 on: June 13, 2009, 09:40:38 PM »
looks like a bit the RTV sealer ducati uses instead of a real gasket.  probably not the issue.
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
A.duc.H.duc.
944 ist sehr gut!
« Reply #6 on: June 14, 2009, 04:38:29 AM »
+1 that just looks like the gasket maker material.
vwboomer
« Reply #7 on: June 14, 2009, 06:22:55 AM »
ok we'll see what happens!
2005 GasGas FSE450
2004 Honda VFR
