Spark Cat Eliminator
Started by Smiles, June 13, 2009, 07:12:05 PM
Smiles
I've been looking all over for one and can't find anything. Do they even make them anymore? The only cat eliminator i can find right now is the one Marving makes...
  -Miles
Chris at DesmoWorld is a sponsor
http://www.desmorados.com/shop/catalog/default.php?cPath=332_358_65_187
Jeff at MonsterParts used to have them. I got mine from him. Call him and check if he can still supply?
Monstermash
Motowheels has the QuatD-
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=660%7CDucati%20Exhaust&productID=5254&showDetail=1&categoryID=671|Monster%20Exhaust&vendoridtodisplay=60%7CQuat%2DD&filterFor=&collection=168%7CEuropean%20Motorcycle%20Parts
I have it on my bike and it's really nice.
tlloyd66
between the Quat D, Marving and Sparks- are all 3 comparable in quality? I know the Marving and Sparks don't block the oil drain plug, but how about the Quat?
Patriotism is the last refuge of the scoundrel
- Samuel Johnson, April 7, 1775
Mash
I got the Quat-d midpipe for my s2r1k from Jeff at monsterparts.  It doesn't block the filter or drain plug.
The Quat-d midpipe reuses the stock header from the vertical cylinder, but replaces the horizontal header pipe.  The horizontal header pipe is in 2 pieces on the quat-d.  I think that's different from the spark and maybe the marving.  They may both be one piece from the head to the s-pipe on the horizontal cylinder.
'06 S2R1000
Smiles
Looks like Monsterparts.com has the Marving for a pretty fair price compared to all three of them. Thanks for the input guys. It looks like they're all pretty much the same pipe, same quality, same design....might as well go for the cheaper one...
   -Miles
Make sure it has a place for the O2 sensor, if you're using it.
yotogi
Quote from: stopintime on June 14, 2009, 01:00:11 AM
+1
AndrewNS
I have a spark on my s2r1000, and it's two piece ( connected by a spring) on the horizontal cylinder. I don't know if they were all like that or not. It fits nice and the quality's good, but I can't compare to the other options you mention cause I've never seen them up close.
Smiles
So even though i have an S4R, could i technically use the mid pipe set up that says it's for an S2R? The Marving mid pipe on  Monsterparts.com doesn't have the 02 sensor bung...
   -Miles
