Mother's bike won't start again....
Started by JBubble, June 14, 2009, 11:16:15 AM
Ddan
You could have a fried regulator and be getting a partial charge.  Get your meter.
Ducati Monster Forum at
www.ducatimonsterforum.org
herm
Quote from: DDDDan on June 15, 2009, 03:37:09 AM
or if the connection was intermittent, loose.......
i am pushing this option because thats what happened to me last summer. ended up using a zip tie to keep things together. no more problem
Had a customer with a weak stator putting out 10-16V AC (should be at least 40) who ran for months as his stator got weaker and weaker.
My $ is on the improper set-up of your new battery.  Also, there are some batteries now coming out of China that aren't worth the $ 'saved' in the purchase price (IMO).
GAAN
This is a stock Duc battery (Yuasa) purchased from Motocorsa
Put the acid'maflochy in the holes, let it sit for awhile and then charged it overnight with the Battery Tender Plus
Also purchased from Motocorsa
So it better not be chinese shit for the 250 bucks I spent
I'm going to triple check my connections again and clean/grease all the connections to the rectifier and then go over it with my meter
then i'm going to swear at it
erkishhorde
When my voltage regulator blew up on my bike it also took out the charge fuse. Found that out after I went about 60 mi up a mountain and came back down. Was on my way to get gas and bike just died one me.
Quote from: Mother on June 14, 2009, 10:04:49 PM
Next question
How many miles can a duc go on just the battery with a system that is not charging?
GAAN
K got my meter
Fully charged battery read 13.5 volts
Turned on the ignition 12.7
Turned it off and rechecked the standing voltage 12.9
Quote from: Mother on June 15, 2009, 09:59:30 AM
K got my meter
How about with it running at 3k - 4k rpm?
GAAN
Quote from: Speeddog on June 15, 2009, 10:05:35 AM
Checked battery again
Ignition off...14.5
Running at Idle...13.8
Running at 4500RPM...14.2
GAAN
Quote from: Speeddog on June 15, 2009, 10:36:53 AM
14.5 at ignition off  ???
Yeah...it actually climbed from the check 10 minutes before
and the meter is new and spendy, contacts are clean
splain me that lucy?
is it Voodoo?
Based on those numbers, I'd say put the meter in a backpack or tankbag, and ride around for 15 minutes, then check again.
herm
and let us know how the swearing at it works out....
i usually end up swearing at myself when i figure out what i was doing stupid.
scott_araujo
Just a simple thought: you replaced belts and battery recently and now it's running funny.  If the timing marks line up I'd suspect the battery.  Can you borrow J's battery for a little while?
Scott
JBubble
Quote from: scott_araujo on June 16, 2009, 06:58:45 AM
Scott
He's already using my car while his is getting finished, I'm not giving up my battery too.
Quote from: JBubble on June 16, 2009, 08:40:54 AM
What'd he do to the jeep now?
