Mother's bike won't start again....
Started by JBubble, June 14, 2009, 11:16:15 AM
JBubble
Quote from: NAKID on June 16, 2009, 10:01:35 AM
What'd he do to the jeep now?
Its been getting rebuilt for the past couple months. I couldn't begin to name what all is being changed on it cause I wasn't paying any attention but they're really beefing it up apparently. Mother says its gonna be 'badass'. In the meantime, he's driving the Audi.
So does this mean that you won't be standing around waiting for him to get out of a ditch why frying the clutch again?
JBubble
Quote from: NAKID on June 16, 2009, 11:02:27 AM
One can only hope.  [thumbsup]
We'll continue with the diagnosis of his bike soon. Not much time between working and sleeping for the next couple days.
GAAN
#33
48hrs later
battery still holding at 13.1
taking it for a ride later tonight
<later>
Engine fired right up initially and at destination
after ride
battery at 13v
4500rpm 13.2v
soooo, any ideas nick?
Ddan
Quote from: Mother on June 17, 2009, 06:03:31 PM
48hrs later
<later>
after ride
battery at 13v
4500rpm 13.2v
The battery will probably read 12.4 or so after a few hours, 13.2 @ 4500 might be low.  You checked the plug connection for the regulator?  Is it hot when the bike is running?
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: DDDDan on June 18, 2009, 03:43:21 AMYou checked the plug connection for the regulator?  Is it hot when the bike is running?
Certain models of Honda (VFRs and VTR1000s from the late '90's early '00s) had common regulator/rectifier problems that often stemmed from bad earthing of the reg/rec - it might be worth checking it's not corroded where it bolts to the frame...
big
GAAN
It is uncomfortble to leave your hand on but i wouldn't call it hot
Quote from: Mr Natural on June 18, 2009, 04:13:22 AM
13.2 is low IMO..
How low?
like broken low?
Quote from: bigiain on June 18, 2009, 04:15:03 AM
big
I think it might be worth it to just pull it and find a new one
anyone have a source for one not from Ducati?
I haven't looked yet but I imagine they are spendy from Italy
The plastic plug on the regulator will start turning brown if it's getting too hot.
Same for the wires.
The regulator itself will get hot to the touch when the bike has been running for a bit.
Not OW! F*CK! THAT'S HOT!, but definitely too hot to keep your hand on.
13.2 is a bit lower than I'd like to see.
How long were you riding last night?
On my single-phase '95 M900, the good regulator was running and at higher rpm (3-4K) it was warm to the touch but you could leave your hand on it indefinitely.  If yours is too hot to keep your hand on it, you may have funky-ness going on inside the regulator.  95% of the time on the 3-phase systems, all charging issues are the regulator.  Stators are usually like a light-switch.  (either ON or OFF)
Used regulators (since 95% of the time they're good, I've had no problem using a used regulator) sell for about $50.
GAAN
Quote from: Speeddog on June 18, 2009, 12:05:05 PM
Same for the wires.
15 minutes
The plug is nice and white and the wires are not discolored
scott_araujo
If it hasn't been menioned already, check for corrosion on the connectory from the regulator.  It's a common source of problems.  Just undo the connector and see if it looks dirty.
Scott
Major Slow
big
I love the way you guys say ground.
You cannot argue with crazy because crazy is not willing to be convinced. Hell, it's not even willing to listen to the arguments.
Your (slightly) low charging rate can still be from the connections, particularly if you are measuring at the battery.  By the time the stator connection turns brown you usually have major resistance and a pretty big voltage drop.  Clean, tighten and pack that connection with dielectric grease.  At the least, this is good preventative maintenance.  While you are at it, also clean the battery connections regulator ground and the engine ground.  Now test again.  If you are putting out 13.5V or better, problem solved.  Also, since your charging rate is close you may want to compare your meter with a known good meter.
If you need a regulator, you can buy a good aftermarket here:
http://www.electrosport.com  or http://www.ca-cycleworks.com
You may also want to read through this:
http://www.electrosport.com/technical-resources/library/diagnosis/fault-finding-guide.php
GAAN
Cool
thanks for the links Howie
I appreciate it
