February 11, 2025, 10:14:02 AM *
Pages: [1] 2   Go Down
Author Topic: Curious...looked and can't really find an answer...  (Read 4068 times)
tonkoshala
'02 S4
« on: June 14, 2009, 09:45:56 PM »
Is the SR2 1000 as fast as the S4 or a better bike? I know the S4 is a 4 valve maintenance is a PITA on them comparably speaking. They put close to the same number as far as HP and TQ are concerned; with the S4 having a slight edge there, but the Sr being a bit lighter. Now that's stock. I saw that the SR with just headers alone can be bumped to 117 HP which is 16 more than the S4.
Spidey
Crashin' mofo
« Reply #1 on: June 14, 2009, 09:56:11 PM »
Ok, let's be clear what you're talking about here.  There is an s2r 1000, an s4 (916 motor), an s4r (996 motor) or a s4rt/s (999 motor).  All the s4/s4r/s4rt put out substantially more HP than the 1000.  They all share the ST-based frame with the S2r 1000.  And they all have at least as good suspension as the s2r1000, if not better.
So is your question whether the s2r1000 is faster than any of them?  I'm pretty sure the answer is no, but that it doesn't matter.  Monsters aren't drag bikes.  As to whether it's better, that is a matter of opinion.  I really like two valve air-cooled monsters, but that doesn't make them 'better.'  On pure numbers, the water-cooled bikes have the s2r 1000 beat.
tonkoshala
'02 S4
« Reply #2 on: June 14, 2009, 10:24:01 PM »
Bro did I really sound that ignorant? lol I've had my S4 for almost five years now Smiley And wouldn't have gotten it if I wanted a drag bike...Now I am no doubt far from an expert.
The Sr is lighter and you only need headers to bump it up into the higher HP bracket. S4 came stock with the 916 with 101HP SR has a 992? with 95HP. Lighter with headers would the SR take the S4 on the track?
Power to weight.
SR2 1000 392 LBS 95HP 51TQ
0.5274 HP
S4 425 LBS 101HP 67TQ
0.5233 HP
So looking at those figures it would seem that the SR would be the quicker bike on the track...Now that is both at stock. So even without the headers it looks to have a very small advantage. Does the torque give the 4 valves that much more of an advantage on the track? Is that where I am not seeing straight?
« Last Edit: June 14, 2009, 10:29:45 PM by tonkoshala » Logged
Feral 859
« Reply #3 on: June 14, 2009, 10:32:42 PM »
no
tonkoshala
'02 S4
« Reply #4 on: June 14, 2009, 10:36:17 PM »
Ok just checked and the 08 S2R had 69TQ so that would be out of the question...
tonkoshala
'02 S4
« Reply #5 on: June 14, 2009, 10:37:41 PM »
No that's great. That's the kinda answers I'd get over at the section 8 forum  bang head
Feral 859
« Reply #6 on: June 14, 2009, 10:40:19 PM »
Ask a stupid question, get a stupid answer.
Spidey
Crashin' mofo
« Reply #7 on: June 14, 2009, 10:45:44 PM »
Edit:  looks like this discussion has gone downhill while I was typing my response below.   Undecided
Sorry, but you did refer to some bike called an sR, which doesn't exist.  Nor does a Sr2.  Then you asked which bike is "better."
As for the question as to which would be faster at the track, I expect it would be the one with the better rider.   The S4 has less clearance (low mount pipes and old-style rearsets) than the S2r 1000, which would hamper it's ability to really get cranked over, particularly in the hands of a less experienced track rider.  But the top end of an water-cooled motor stomps on an air-cooled motor and IIRC, the S4 has *slightly* better suspension.  The riders being equal?   Who knows.  It would depend on a billion factors.  Personally, I'd probably choose the S4 on a more open track and the s2r on a tight technical one.  I just hate scraping stuff.
Also, I wouldn't trust the numbers you're using.  For example, I think that the HP numbers you're looking at are not apples to apples.  The S4 is measured at the rear wheel (at least I think it was the rear wheel).  At some point (2005, maybe?), Ducati started measuring HP at the crank.  So your HP number for the S4 has parasitic loss that the S2r does not.  I'm not sure those are apples-to-apples weights either.  I seem to remember that Ducati changed how they measure weight at the same time as the hp measurement change-over.  Finally, don't quote me on this, but I *think* the S2r 10000 and S4 may have different transmission ratios, which would have a significant effect on the straightline performance of each.
So my answer is that I can't tell you which is better nor which is faster at the track.  Lot of help, eh?
« Last Edit: June 14, 2009, 11:13:22 PM by Spidey » Logged
tonkoshala
'02 S4
« Reply #8 on: June 14, 2009, 10:52:47 PM »
someone doesn't know the difference between ignorance and stupidity...
Thanks bud. The SR bit was a typo. So my reasoning for the view was not too far fetched?
Feral 859
« Reply #9 on: June 14, 2009, 10:55:39 PM »
Thanks  Roll Eyes
tonkoshala
'02 S4
« Reply #10 on: June 14, 2009, 11:02:59 PM »
Thanks  Roll Eyes
 Grin
Duc-Duc-goose
« Reply #11 on: June 14, 2009, 11:13:20 PM »
To me HP numbers are like measuring of memory, or prime example my iPhone, it's an "8 gig", when in actuality it is 7.2 gig, they are all SLIGHTLY different, but essentially 8 gig; excellent point on hp measured at crank spidey!!  Tongue
Omnipotent Potentate
Personal Pretext
« Reply #12 on: June 15, 2009, 06:11:29 AM »
Grrr grump grump grump... easy kids
Here's my opinion on the matter.  The S4 does have more power, and it has some history to it, being the 1st 4v monster... On the bad side, it came with chack clip-on things and experienced Duc techs run and hide if you ask them to service the valves on that engine.
S2R1000 - solid bike, though known to have some tech issues.  I'm a sucker for the air cooled look over the water cooled (though the s4 radiators no soo huge), and the SSS is a nice touch.
One of the biggest decision factors for me might come down to the valves.  I watched a 4v valve service teaching demo, done on those heads and saw in person what a hassle it was to do.. and this was on a head that wasn't attached to anything so it could be moved around and futzed with.. If you're willing to invest the money or time each time you have to do those valves you're more patient, or better financed than me  Grin
I don't think you're going to see 117 hp on the S2R1000 with just a set of headers... that's a BIG hop up from teh stock trim numbers.
Mash
« Reply #13 on: June 15, 2009, 08:11:32 AM »
With just a set of headers and the termi kit (slip-ons, airbox, ecu) my s2r1000 puts out 92hp at the rear wheel.
'06 S2R1000
« Reply #14 on: June 15, 2009, 08:51:14 AM »
Give a look see here, Brad Black's real world numbers:
http://www.bikeboy.org/sr21000.html
S2R1k - 83 HP, 58 ft-lb
http://www.bikeboy.org/monsters4.html
S4 - 101 HP, 64 ft-lb
Given the same rider, I'd expect the S4 to be quicker around a track, unless it was *really* tight.
S2R1k can get in the vicinity of 90 HP with a full exhaust system, open airbox and fuel system tweaking.
It will need a good chunk  of $ thrown at the motor to get to ~100 HP.
S4 can get to 105 HP with cans, open airbox and DP ECU.
S4 is a lot more work to do the valves; twice as many to do, and a lot more crap has to come off and go back on.
Pages: [1] 2   Go Up
