Fork diameter questions
Started by Alex, June 16, 2009, 05:26:44 PM
Alex
I'm interested in getting some higher clipons for my bike, which currently has 996 forks on it. I need to get clipons that are designed to fit the same upper diameter as my 996 forks.
As of now, I have stock clipons from a 999 installed (I just forgot what size diameter they are).
The only Cyclecats I can find are designed for the old S4. What size was that? Will it fit?
http://www.oncycles.com/catalog.asp?r=1&pn=MCB00154
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting half-open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded), CRG clutch/brake levers.
Your forks are 53mm top and bottom.
Monster forks are 50mm top, 54mm bottom.
And those S4 parts won't work.
Alex
Thanks for the info. So I need 53 mm clipons... These were listed under the 53mm category, but I could not confirm their size. They are for a Multistrada 1000DS from 04-05.
This they might work?
https://www.oncycles.com/catalog.asp?r=1&pn=MCB00149
I don't know the fork diameter on MTS....
Best to check with OnCycles before ordering.
trenner
Quote from: Speeddog on June 16, 2009, 05:44:21 PM
To persevere in this a bit with respect to my bikes:
Will these, intended for the (01 to 03) S4, fit a 2004 S4R?
Or, put another way, what's the S4 fork diameter at the top?  Same as the S4R, or not?
Kopfjager
trenner
Thanks, handy chart!
Also, I notice that the Tall Boys are in stock there now, finally!
