February 24, 2025, 10:54:20 PM *
Pages: [1] 2   Go Down
Author Topic: 696 top end  (Read 2828 times)
« on: June 17, 2009, 01:17:40 PM »
well i maxed it today
on the 696 w 14t sprocket roads italia exhausts with dp limiters stock ECU
212/213 kph on the speedo when the rev limiter hit
probably would have been a bit more with full leathers (jeans with hard armor) and better aerodynamic helmet/hump combo.
i think the DP Ecu will give another 1000rpm (others input here please)
mstevens
Monsterless
No Monster of my own, but my wife has an '09 696
« Reply #1 on: June 17, 2009, 05:08:01 PM »
Randall thinks you can probably squeeze out another 13 kph...
herm
« Reply #2 on: June 17, 2009, 07:13:54 PM »
or,............that 14t sprocket came from bellisimoto....
slim_grizzy
« Reply #3 on: June 17, 2009, 07:44:01 PM »
If you maxed it out with by hitting the rev limiter, there's not much else to make you faster other than changing gearing or the ECU.  Go back to the 15t sprocket or get the DP ECU to bump the rev limiter up another 500rpm if you want to go faster.  Aerodynamics or power aren't the issue at this point.
« Reply #4 on: June 18, 2009, 01:16:45 AM »
eh not looking for more really, just reporting to you guys. figured you stateside guys don't get much chance to do that. but i may swap to 15t and see what i can do.
so the DP ecu gives 500 more?
« Last Edit: June 18, 2009, 01:20:40 AM by Raux » Logged
z0mb1e_DUC
« Reply #5 on: June 18, 2009, 03:17:38 AM »
I believe it bumps redline to 10,500. Haven't had a chance to test that yet Evil
'09 m696 Dark
psycledelic
« Reply #6 on: June 20, 2009, 05:16:54 AM »
"No  Police, I swear it was just research for the DMF", Raux said as he was being put into the squad car.
Where might you be that you can do that?
06 S2R800 - the wife                         Dolph
04 999s - the mistress
gt78fin
« Reply #7 on: June 20, 2009, 05:52:14 AM »
I get too scared whenever I go over 150 kph so  bow down to Raux
« Reply #8 on: June 20, 2009, 05:56:20 AM »
open section of autobahn... germany!
i guess officially it's 195.96 kph since there's an 8% error built into the speedos.
but seriously glad i don't have a 1198 or something. research would be scary fast.
psycledelic
« Reply #9 on: June 20, 2009, 01:02:33 PM »
Now that is cool.  My non-traveling ass from North Carolina invisions the Autoban as this illustrious stretch of unrestricted highway littered with Porshe, Ferrari, Lotus, and Mercedes jockeying for position as their drivers, dare I say, race for their brands supremesy.
crazy bike girl
aka msincredible
« Reply #10 on: June 20, 2009, 06:39:20 PM »
That's true for some parts of it, although there are also parts with speed cameras.  It's mostly German cars, lots of VWs too.
The drivers there are much better about staying to the right unless passing.  It's a nice drive/ride. waytogo [moto]
« Reply #11 on: June 21, 2009, 01:49:01 AM »
previously we had talked about this, but the ones to be careful of are the BMW, Audi and Mercedes station wagons. they will be doing 240+
staying out of the left lane is not only the law, but also a safe thing to do. i was doing 180 the other day and had an audi avant blow past me.
there are speed cameras and they are serious about following the limits. but unlike the states instead of jail for a certain amount over they just take your license for a time. had a friend that was doing like 60kph over and had it taken for a month. typically if you are more than 30kph over it's more serious than just a fine.
the normal recommended speed in unlimited areas is 130kph. and that is also the most common posted limit. it's still faster than the states.
but you will find the limits are for reasons, city exits, bad roads, construction, etc. not just because they want them.
IdZer0
BE
« Reply #12 on: June 22, 2009, 11:18:44 AM »
Autobahn feeling: returning home from a trip to Italy, after 2 hours in a traffic jam, the road opening up from 2 lanes to 5, going 195kph uphill in the left lane (4 others were slower). Then seeing a Porsche in your rear view mirror tailgating; trying to tell you to move your slow ass out of the way.
replaced by 2011 848 EVO
darthmoto
.: 2009 M696 White :.
« Reply #13 on: June 23, 2009, 07:36:47 PM »
Well, I think this proves that a 14t sprocket wont take away top end. Tested top speed on a stock 15t 696 is 129-131mph.. 213kmh is 132.35mph.. So you gained top end... I was only able to get 131mph in full tuck on a straight smooth road.. Motor was limited by drag, not rev limiter..(I'm not that heavy)
« Reply #14 on: June 23, 2009, 09:39:27 PM »
don't forget the 8% speedo correction. my corrected speed is about 121. so i lost about 10mph top end.
Pages: [1] 2   Go Up
