Rear brake light bulb is out. One filament gone.
Started by EEL, June 18, 2009, 10:14:19 AM
EEL
My light bulb is out on my rear brake light. It turns on when I brake, but the dimmed setting thats constantly on is not working. I'm assuming its a 2 stage bulb. I had to replace it on my old bike it noticed its a standard type used in most cars. Anyone know the part number is? (NOT the ducati part number but the actual one). I wanted to pick one up from a local Auto store today.
Thanks
Porsche Monkey
Should be an 1157 or a 1257. Both should work. Just take it out and match it up.
EEL
ScottRNelson
Pay the extra cents (or dollars) for a heavy duty bulb.  It will last much longer.  I think I went through four or five rear bulbs in the six years that I had my Monster.  When I finally put in a heavy duty bulb it lasted as long as the bike did.
DucatiSTi
The bulb on my friend's 999 always burns out - especially since the bike has had a tail chop - the vibration from his beast causes the filament to snap
Yes, the heavy duty one lasts longer -the only other way is to go LED
I think the bulb is a P21 5watt
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
LED Bulb! i sold 2 of them to someone here on DMF, its adirectly swap for the bulb and its super bright.
Keld
EEL
I'm going to go buy a bulb..
BUT. I'm gonna make an LED Brake light..thats a great idea! I might cram in some more LED's though.
Just so its blinding.
Thanks for the link!
EEL
So I have a question, how do you drill mini holes like that?
Ddan
Quote from: EEL on June 19, 2009, 07:55:37 PM
Mini drill bits.
;D
Ducati Monster Forum at
www.ducatimonsterforum.org
Keld
Major Slow
Quote from: Keld on June 20, 2009, 06:32:30 AM
+1
Be sure to use Lexan (polycarbonate)
I looked at the plans and why wouldn't a proto board from digikey work just as well. They come predrilled and they are easy to cut. Or conversely why lexan?
You cannot argue with crazy because crazy is not willing to be convinced. Hell, it's not even willing to listen to the arguments.
EEL
I was wondering the same thing myself. Why lexan. I just figured it might be a heat issue. Lexan does have a fairly good resistance to temperature.
Just a guess. I'm as confused about it as you are.
