January 26, 2025, 01:38:15 PM *
Author Topic: Exhaust Gaskets for S2R800  (Read 2349 times)
psycledelic
« on: June 19, 2009, 08:30:36 AM »
Anyone know if the exhaust gaskets for an S2R800 are a common size or am I gonna have to make an hour drive to the shop?
06 S2R800 - the wife                         Dolph
04 999s - the mistress
dlearl476
« Reply #1 on: June 19, 2009, 08:53:55 AM »
Do you need them NOW?  If not the internet is your friend.  (I buy 99%  of my parts online from ProItalia.  My local dealer never has anything I need in stock.  And fwiw, when I buy stuff like this, I always buy twice as many as I need so I have them already the next time I need them.)
If you do need them today, you could pull one out and see if a local motocycle shop has one.  (Sorry I have no idea if they are a "common" size or not.)  I also think NAPA may have a size that would work.
psycledelic
« Reply #2 on: June 19, 2009, 09:12:05 AM »
Yea, it's now or no bike.  I have one out and it looks like a run of the mill doughnut style gasket, but those Italians are sneaky.  I am gonna go shop around the local auto / moto shops.  I was just being lazy and hoping I would get lucky and someone online would know.
Good point, I will definately put a couple extra in the toolbox.
dlearl476
« Reply #3 on: June 19, 2009, 09:19:09 AM »
FWIW, the ones I bought to put in when I re-install my RR exhaust are 47mm X 39mm X 2.2mm and they are Part 037084005.  You might want to call a dealership and see if that's the same PN for your S2R (I have a '99 M900).  You might want to get a new set of exhaust nuts as well.  NAPA or any foreign car shop will have those.  They are M8 X 1.25 copper locking nuts.
« Last Edit: June 19, 2009, 09:22:38 AM by dlearl476 » Logged
psycledelic
« Reply #4 on: June 19, 2009, 10:01:04 AM »
I actually pulled the nuts/threads and touched them up at work last night (cleaned, tapped, and filed the threads).  I will probably add new ones when I install my new exhaust.  Currently in between exhaust systems and am just installing the stock headers and udder until the new stuff arrives.
dlearl476
« Reply #5 on: June 19, 2009, 10:22:58 AM »
Exhaust nuts are supposed to be locking i.e. one use.  But like everyone else, I use them over an over (until I wised up and simply bought a box of them from WURTH. Luckily, two of my cars take the same ones)  And fwiw, if you're between exhaust systems, you can re-use the gaskets as well.  I have old ones in mine and, like I said, I'm waiting until my RR exhaust gets back from the ceramic coater to install all the new stuff.
One little tip:  IIRC  typical M8X1.25 lock nuts have 13 mm flats (I think) Porsche uses a special copper lock nut that has 12 mm sides and that extra MM helps a TON on the vertical cylinder.  If you have to buy some, try an indy Porsche shop.
Oh, and by "lock nuts" I mean the ones with the top two or three threads crimped.  Obviously NyLocks wouldn't do well in an exhaust application.
« Last Edit: June 20, 2009, 06:40:13 AM by dlearl476 » Logged
psycledelic
« Reply #6 on: June 19, 2009, 11:58:41 AM »
Talk about being ass backwards.  I am ditching gaskets and refurbishing the nuts.  I will definitely get new nuts and studs with the new pipes.  Thx for the heads up and all of the info.
« Reply #7 on: June 19, 2009, 02:31:16 PM »
I ran muy bike for thousands of miles without them and the bike ran fine. it wasnt until i spray painted my udder that i realized i needed one.
psycledelic
« Reply #8 on: June 20, 2009, 08:24:49 AM »
Didn't smoke around the engine outlet?  I set mine up without one and is smoked pretty bad.  That was before I pulled the nuts and studs and cleaned them.  I am gonna try again.  No one around here has a gasket that is even close and the shop is gonna order me 4.
dlearl476
« Reply #9 on: June 20, 2009, 09:27:45 AM »
Personally, I wouldn't run it without gaskets.  IMO, you're better off with old ones than no ones.  YMMV.
« Reply #10 on: June 20, 2009, 09:34:58 AM »
nope, didnt smoke. The dealer that did my valve guides left it out and i rode like that for thousands. And i even dynoed it without the gasket. 85hp, 64tq or something like that.
« Reply #11 on: June 20, 2009, 09:40:22 AM »
i cut some cork gaskets and coated them with copper exhaust RTV silicone.
better seal and cheaper.
you have to let the RTV silicone completely dry, which means >24 hours to be safe.
gasket material comes in rolls at any auto parts store
the metal ones are crush fit.  they are fine, but a bead of silicone will seal far far better.
i put a bead on each side of the gasket, let it sit up for about an hour to firm a little bit then torque it all down.  the silicon will squeeze out a bit, but leave it and cut it away (DO NOT PULL) after it all sets and dries.
