January 10, 2025, 06:00:40 PM *
News: Please Help
Author Topic: New Mod Pics...  (Read 2173 times)
johnster
« on: May 19, 2008, 07:36:05 PM »
Just felt like posting pics..... Grin
-The new Motowheels Pressure plate/Half Cover I just installed...Great kit!!
-Matris M3 damper I just finished installing a few minutes ago..... Grin  Decided to mix it up and add some blue to match the spring keepers (okay, it's all they had left, but I thought it might look OK..... Undecided ) and the $$ was right!!   Cheesy What do you think???
« Last Edit: May 19, 2008, 07:37:59 PM by Johnster » Logged
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
« Reply #1 on: May 20, 2008, 12:24:42 AM »
Looks nice waytogo
sydmonster
Street_Cred_Points.com CEO
« Reply #2 on: May 20, 2008, 02:34:04 AM »
good work  waytogo, a bit of white somewere and it id' be very patriotic... if your into that.  Grin - Chris
...Sydmonster - down under
Contact me about your mods and what Street Cred Points you can earn!
arai_speed
« Reply #3 on: May 20, 2008, 06:47:37 AM »
I like the clean look of the clutch cover cover and color of the PP.  waytogo
Was the PP hard to install?
johnster
« Reply #4 on: May 20, 2008, 07:17:52 AM »
Thanks a lot....  Smiley
Piece of cake!!   waytogo  The hardest part was making sure the push rod was seated properly in the throwout bearing....I ended up putting the pressure plate face-down on my workbench with a towel under it, and hammered the push rod into the bearing with a rubber mallet.....After that, you literally just put the plate on (lining up the marks obviously), screwing the bolts into the posts (I used medium strength Loctite), and you're done!!
I just tightened the bolts until they bottomed out, then very gently snugged them up.....The posts are supposedly very brittle, so you can't torque them down, or you risk snapping the post off... The spring preload will keep the bolts in place...
nikkimonster
« Reply #5 on: May 31, 2009, 12:03:53 PM »
i like it. sometimes red on red on red is just too much. it's good to mix it up sometimes.
DucatiTorrey
My wife's super hero is my
Industrial Designer
« Reply #6 on: May 31, 2009, 02:52:15 PM »
+1
  - real place
