April 27, 2024, 02:53:59 AM
M-ROC
Rameses
Splitting the cases
Topic: Splitting the cases (Read 2589 times)
Blackout
Splitting the cases
June 23, 2009, 09:06:01 AM »
Any youse guys done this?
I ask because it seems no one can weld where my kickstand/rearset bolts fit into the sump unless I simply bring them the part, not the whole bike.
2003 Ducati Monster 800
2003 Honda CR250
2008 KTM 990 SuperDuke
DucHead
No garage queens
Re: Splitting the cases
June 23, 2009, 03:50:28 PM »
No, but if you want, bring it over to my place.
"45"
Blackout
June 24, 2009, 05:13:52 AM »
I'll probably do that, thanks.
You gonna be around this weekend and do you mind (longer term) storage?
It can sit next to your neighbor's antique record player
2003 Honda CR250
June 24, 2009, 06:33:20 AM »
Before you go welding on the case, or worse yet, splitting the cases....
What is wrong?
Stripped thread?
Or is it cracked?
Blackout
June 24, 2009, 07:22:21 AM »
Quote from: Speeddog on June 24, 2009, 06:33:20 AM
What is wrong?
Stripped thread?
Or is it cracked?
The bolt holes securing the kickstand to the sump were broken off and one of them has gone through to the sump producing a small oil leak. I've read on this forum that is not a very unusual problem and that many have had that area welded successfully. I had hoped to have it welded with the engine still in the bike but have been told that is not an option. Any ideas Speeddog?
2003 Honda CR250
June 24, 2009, 07:47:09 AM »
I've had cases welded on an assembled bike, fixing that same kind of issue, other than it was a 996.
In that situation, it hadn't cracked through, but IMO that's not significant.
For a more durable repair, we put in some TimeSerts.
Blackout
June 24, 2009, 07:52:05 AM »
Yeah, I figured whoever does the job would need to build up that area and put in a time-cert.
2003 Honda CR250
June 24, 2009, 07:58:21 AM »
The area needs to cleaned up and areas ground out with a die grinder or the like.
The welder can give you direction on what needs to be done.
Those 2 bosses are machined to the same level as where the sidecover sits, so it needs to be built up to a bit past that level and then *carefully* 'machined' back flat.
When I say 'machined', I did it with a die grinder and files... just have to go slow and careful.
You're more or less in NASCAR country, there's got to be some talented welders around.
Also, give ducvet a shout.
He's not *real* close to you, but IMO he would have some good feedback for ya.
