January 26, 2025, 01:54:00 PM
Should i go to a 14 counter sprocket?
Topic: Should i go to a 14 counter sprocket? (Read 7000 times)
118811
June 23, 2009, 10:41:41 AM »
Hello,
I have a 98 Monster 900, which I use for errands around town & for short fun rides...not a whole lot of freeway.
I find myself in between 1st & 2nd gears alot...so I am wondering if I should gear down.
Please give me pros & cons.
Aloha for Honolulu!!!
Re: Should i go to a 14 counter sprocket?
June 23, 2009, 10:44:28 AM »
What gearing are you running now?
yotogi
June 23, 2009, 10:46:32 AM »
Assuming 15T up front right now...
Pros:
- Easier low speed behavior.
- Easier to get that front end up?
Cons:
- Slightly worse fuel economy due to higher RPMs. Maybe? Does it even matter?
- Slightly worse chain wear. Stepping up in the rear is supposed to be better on the chain. Again, does it even matter?
- Slightly lower top speed. Matters?
Go for it. The pros greatly outweigh the cons.
Celli
Ducati Codatronca
June 23, 2009, 10:52:10 AM »
+1
Ducati Codatronca: Concerto Molto Vivante!
The best kind of whore is a
June 23, 2009, 11:34:48 AM »
There are no cons, just do it.
On my 00 M900 I ran a 14 in the front and a 41 in the back (i think that's -1/+2 from stock)
Not only did 6th gear become usable, the bike flat out ripped and even on a day ride that saw lots of throttle, I still got 50 mpg. Sometimes more, and I was running a PC2 that was toward the rich side.
Do it! Do it now!! What are you waiting for!?!?
118811
June 23, 2009, 11:37:56 AM »
Thanks for the replies!!
Currently running 15 front & 41 rear
scduc
June 23, 2009, 12:09:34 PM »
For the price of a new front sprocket, there is no reason not to. If you don't like it, you can always go back. Now, if you change the rear, I was told that you may need to change the chain.
08' S2R 1K That was close damn near lost a $400 hand cart.
ab
ab
ab
June 23, 2009, 02:14:56 PM »
After using 14T couple of times, I am going to go back to 15T this time. I want to see the difference in the chain rub and awful chain rub noise. I am guessing the 14T is the culprit. I'll see if 15T makes a difference for now.
Last Edit: June 23, 2009, 06:03:57 PM by ab
620M 2004 Dark i.e.; ~ 57K miles (all me); Looking to swap out engine now.
Honda Grom 2015 ~ 3500miles so far. Love this lil bike
Statler
June 23, 2009, 02:37:09 PM »
Quote from: 118811 on June 23, 2009, 10:41:41 AM
Hello,
hard call, but as others said cheap trial and easy to go back if not.
If you're between first and second a lot then the attempt would be to be in second more. usually the 14t works best for folks who hate how their bike acts in first. If you can get into second you're a little different issue. It is possible the shorter gearing would allow you to be in second more often and not be swapping bettween the two all the time....so you won't be lugging around in second.
let us know.
It's
still
buy a flounder a drink month
ute
I Have Titanium
June 23, 2009, 03:09:21 PM »
to me its a no brainer ...this is a must do mod totally transforms the Monster
psycledelic
June 23, 2009, 03:12:41 PM »
Works great for that "in between gears" problem you have in town. Gives you a little more at the get go. Don't expect to all of a sudden come out of the whole like a rocket or anything. I think the 14 tooth sometimes gets elevated to greek god status during these threads. I like mine, and won't go back, but less because of the blazing takeoff and more for the fact that I think my bike rides better day to day. I would say to give it a go and see if you like it.
06 S2R800 - the wife
04 999s - the mistress
Statler
June 23, 2009, 03:19:09 PM »
mine is stock and I'm happy (the s4rs is geared lower than the s4r it replaced)
....people shouldn't be changing their gearing unless they can identify an actual problem lower gearing would solve. This thread is good, but so many people just do it because everyone says they should and can't explain what is wrong that they want to change.
It's
still
sno_duc
June 23, 2009, 05:35:05 PM »
Given you ride in the USA, I think it is a mod worth trying.
If you ride in Europe and use the Autobahns regularly I would stay with the stock gearing.
A conclusion is the place you got tired of thinking
peanut_man
June 23, 2009, 05:57:40 PM »
Quote from: Statler on June 23, 2009, 03:19:09 PM
Some time you won't know what's 'wrong' until you try to change. Then you'll suddenly realized what you have been missing.
I did 14T change on my old Multistrada. It was so good, that's one of the first thing I did to my M696 once I get it.
OP: Do it, do not hesitate. Only reason Ducati geared the final drive so high is only emission / noise requirement. You bought the bike already, those are not an issue and enjoy.
2005 Buell XB12S | 2006 Honda CBR 600RR | 2005 Ducati Multistrada 1000DS |
2009 Ducati Monster 696+
crazy bike girl
aka msincredible
Reply #14 on:
June 23, 2009, 08:54:47 PM »
In my case someone did it for me and I miss my stock gearing (switching back soon).
photo FAQ
