February 24, 2025, 12:37:35 PM *
News: Please Help
Author Topic: Question about S4R oil cooler  (Read 1341 times)
pennyrobber
« on: June 23, 2009, 12:16:52 PM »
The oil coolers on the 2004-ish S4R bikes have what looks like a sensor on the left hand side. Is this for temperature or pressure maybe? Also, could you block that sensor hole off somehow?
« Reply #1 on: June 23, 2009, 01:41:31 PM »
Pressure sensor is on the engine cases just above the filler. It's more likely a temp sensor.
If you can find out what the thread is you could plug it.
DucHead
No garage queens
« Reply #2 on: June 23, 2009, 03:35:28 PM »
Hmmmm...sensor??  My '05 has an oil line that feeds the heads.
« Reply #3 on: June 23, 2009, 06:37:30 PM »
I'm assuming the OP is thinking of using an S4R cooler on a 2-valver.
You can block it off for that application.
For retrofitting to an S4 or just for S4R use, you would need that oil line for the heads, as pompetta noted.
pennyrobber
« Reply #4 on: June 24, 2009, 08:50:49 AM »
Bingo. The S2R has an oil cooler but the S4R oil coolers look much cleaner IMO. I especially like the look of the oil cooler on the Testastretta S4R's but still haven't found a used one for sale. An older S4R cooler popped up on ebay thus the question. Thanks for the replies.
DucHead
No garage queens
« Reply #5 on: June 24, 2009, 11:05:12 AM »
I have an extra oil cooler from an S4R...cleaned up, no leaks.
pennyrobber
« Reply #6 on: June 24, 2009, 11:23:43 AM »
You have my attention. PM sent.
