February 24, 2025, 01:49:40 PM *
Author Topic: Best source for stainless brake lines?  (Read 1761 times)
Bones
In spanish she calls it
'02 M620 - '00 996
« on: June 23, 2009, 12:43:05 PM »
Hey guys,
Was wondering if you know where I could find reasonably-priced stainless steel brake lines for my monster (M620).
also, is a new clutch slave bleeder screw a dealer-only part?
TIA
-Frank
I'm a loner, Dottie...a rebel...
woppini
« Reply #1 on: June 23, 2009, 01:05:38 PM »
Spiegler
http://www.spieglerusa.com/
What happened to the bleeder screw?
« Reply #2 on: June 23, 2009, 03:23:08 PM »
You could try yoyodyneti.com on the bleeder
DucHead
No garage queens
« Reply #3 on: June 23, 2009, 03:33:12 PM »
Spiegler
+1  great products and great customer service.
Langanobob
« Reply #4 on: June 23, 2009, 04:08:31 PM »
You can also get Galfer brake lines from California Cycleworks, who help this board with sponsorship!
bdfinally
« Reply #5 on: June 23, 2009, 05:16:23 PM »
+2 on SpeiglerUSA
Bones
'02 M620 - '00 996
« Reply #6 on: June 24, 2009, 05:03:12 AM »
LOL, well, I got a little overzealous tightening the bleeder screw when I was bleeding the clutch lines and sheared off the top of it. Luckily, I had an extra bleeder from my spare engine, so I used that one.
I'll give CA cycle works a try.
I just switched to clipons and the bend on the the banjo fitting on my reservoirs is barely clearing the gauges, causing a rather aggressive bend on the lines, and keeping me from lowering the instrument panel. It's fine as is, but I figured down the road I can get SS brake lines with straight banjo fittings so I can do it right.
dlearl476
« Reply #7 on: June 24, 2009, 08:10:16 AM »
I use CycleBrakes who are a Galfer dealer and can make custom lines.
KEH
« Reply #8 on: June 26, 2009, 04:16:02 AM »
I got a galfer line for a good price from these guys: [urlhttp://www.powersportsuperstore.com/[/url]
Bones
'02 M620 - '00 996
« Reply #9 on: June 26, 2009, 10:48:53 AM »
hmmmm. looks like galfer doesn't make lines specifically for an '02 M620. other choice would be custom lines.
I noticed the newer dual disc set ups on the 696s have one line that goes from left caliper to right caliper, then from right caliper to master unlike mine which has one line from each caliper running up and then merging into one line behind the headlight bracket and then ending to the master cylinder (which I'm not crazy about). I rather have it setup like on the newer bikes.
anyone know if I could do the 696 set up with my calipers?
Cider
« Reply #10 on: June 26, 2009, 11:41:01 AM »
I don't know why not.  Does the 696 have some sort of fastener on the fender so the brake line doesn't rub on it?
BTW, I got custom Galfer lines from CycleBrakes for two different bikes, and they were pleasant to work with.  I would be inclined to buy from CA Cycleworks, though, as they are a long-time board sponsor and a genuine Ducati enthusiast.
