February 24, 2025, 01:56:36 AM *
Author Topic: Horn not working Ducati S2R 05  (Read 1120 times)
Ducatiloo
« on: June 25, 2009, 04:45:07 PM »
I had a 2005 S2R.  My horn is no longer working, I tried my stock and my aftermarket nautilus horn.  I've tested both any they honk without issue, yet neither when set up as intended work.
Things I have checked / changed
1) The horn fuse
2) The horn switch. My old one didn't work so I bought a "new"  left controls that has tested ok.
3) I have tested every wire and all showed that they could carry a current.
4) The relay for the nautilus horn.
5) Verified that both horns I have tried actually work.
All test ok but not a peep.  This is driving me crazy any thoughts or ideas?
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
« Reply #1 on: June 25, 2009, 05:14:26 PM »
Strange, EXACT same problem with me i tested both my horns and both work. the relay is working, but when i hook it up it doesnt work. checked hte wireing and re soldered eveyrthing. i checked my fuses too. no idea whats wrong.
Ducatiloo
« Reply #2 on: June 25, 2009, 05:23:45 PM »
I keep repeating the same steps muttering to my self "this isn't that complicated"  Angry
« Reply #3 on: June 26, 2009, 04:06:07 AM »
Check that you have a good ground (black wire).
« Reply #4 on: June 26, 2009, 05:55:24 AM »
Mine is grounded to the frame and has a good connection. sanded down the connector and all.'
Ducatiloo
« Reply #5 on: June 26, 2009, 06:35:25 AM »
+1 I used a wire brush to clean the connection.
