February 24, 2025, 04:29:43 PM *
Author Topic: carburetted M900 rough running '96.  (Read 1245 times)
CX500
All you need...
« on: June 25, 2009, 05:10:01 PM »
Hoping someone might recognize this symptom:
Rough running, sputtering, and coughing at steady throttle.  Give the throttle a twist and it runs great -- lifts the front wheel.  Idle is OK, maybe a little rough.
Sounds like a carb issue to me - maybe a plugged jet before the needle jets take over, but it also smells very rich after running rough.  This made me wonder about electrical.  I am going to change plugs tomorrow.  Try to check one thing at a time.
Any insight would be greatly appreciated.
MarcuSS
'96 M900 -- Still get tingles  before each ride.
« Reply #1 on: June 25, 2009, 05:17:59 PM »
MarcuSS
Replace the needle jets/emulsion tubes.
I have the same bike.
beethoven
« Reply #2 on: June 26, 2009, 01:44:48 AM »
+1 Needle jets. They get worn and let fuel through at low-mid revs causing roughness and richness. I have 97 M900 and have just done them at 45000 km. Fuel consumption has improved about 15%. The mechanic photographed the tube and it had a definite oval shape rather than circular.
97_M900                                                     07_Triumph_Sprint
CX500
All you need...
« Reply #3 on: June 26, 2009, 08:23:45 AM »
Thanks for the replies.  This is exactly what I was thinking, especially at 35,000 miles.
Now, do I do some work on these carbs, or go for the flat-slides I always wanted.  Hmmmm...
MarcuSS
« Reply #4 on: June 26, 2009, 02:21:47 PM »
MarcuSS
needle jets will set you back about $100...
Flatslides will be considerably more.
How flush are you? Grin
