14T and Termis on S4Rs?
Started by Joe, May 20, 2008, 05:39:24 AM
Joe
My '07 S4Rs is due for 600mi service, so I'm planning to swap out the front sproket for the 14 tooth.  I'm thinking that I should also make an appointment for the full Termis kit as well and just get it over with.
It sounds like the general feeling is that this is the best set up... If you can swing the Termis, of course.
Thoughts? Options? Other performance mods?
Joe
DoubleEagle
That's what I did and it made a hell of a difference in torque and the sound is unearthly. Should bump up the rear wheel hp by at least 10.
blue tiger
I never went for the 14 tooth sprocket but I had the full system put on before delivery. I have on 08 s4rs. The sound is awesome esp. higher up in the rev range.
I can't comment on how it was before but it is awesome to me esp. when it's engine braking.
I'm here to kick a*! and chew bubble gum...and I'm all out of bubble gum.
LYD
Desmonsters4rs has an 07, he went with the full arrows system,  Dp ECU and an open airbox and it ran like shit at low RPM's until he put the 14T sproket on it and it runs great at all RPM's!
RIP cdc
01 900 monster
01 748
02 900ss (trackbike)
12 1200s Multistrada
LA
Yep. Do both. Absolutely transforms the bike.
LA
hypurone
I'm totally happy with the 14T & the Full Termi system I installed!  [thumbsup] Being a picky MOFO, I also installed a PCIII and had it custom mapped on the dyno.
Most will be happy with what you are planning... You can look drool/listen here:
http://s239.photobucket.com/albums/ff38/hypurone/Monster%20S4RS/
hypurone
One other thought. You had better call the dealer and get em to order the pipes. It can take quite some time unless you are lucky and they have a set in stock. I wasn't so lucky...  :P
zc911
Quote from: hypurone on June 11, 2008, 10:08:09 AM
that looks and sounds great  [thumbsup]
Has anyone chopped the pipes down to match a tail chop?  if so how do you do it and does it affect sound/performance
