December 22, 2024, 08:28:45 PM
Please Help
Holes in the fairings -'splainations?
Topic: Holes in the fairings -'splainations? (Read 4406 times)
enzo
Street: 94 M900 Track: 05 R6
June 26, 2009, 12:29:13 PM »
Will someone explain this to me? It can't be weight savings. Aerodynamics? I've seen it on older race bikes as well as the 250's/125's, but I can't figure out the advantage.
http://www.superbikeplanet.com/image/2009/motogp/assen/hugo/5.htm
we're creepin' between the bullfrogs
Spidey
Crashin' mofo
Re: Holes in the fairings -'splainations?
June 26, 2009, 12:38:37 PM »
I think it's to improve stability when there are bad cross-winds, E.
derby
June 26, 2009, 12:57:18 PM »
like dimples on a golfball.
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
ZLTFUL
WWSDD? Why Anal of course!
June 26, 2009, 01:08:02 PM »
Quote from: derby on June 26, 2009, 12:57:18 PM
Not only is he good looking but he is brlliant as well!
Avatar courtesy of
www.mybadco.com
2012 Panigale 1199
2003 KTM 640 Adventure
pennyrobber
June 26, 2009, 03:05:44 PM »
Not the same as dimples in a golf ball. Golf ball dimples create a turbulent boundary layer that keeps the flow around the golf ball from separating prematurely. The effect is the reduction of form drag. the holes in the upper fairing help reduce the effects of cross wind and some drag but in a completely different way.
enzo
June 26, 2009, 09:37:14 PM »
okay, thanks!
June 26, 2009, 09:57:37 PM »
IMO, it's mostly for when they're laid over like this:
Leaned over like that, a gusty side wind is going to load up the front tire.
May not be too fun at ~300 kph when you're sliding both tires.
When it was windy at El Mirage or Bonneville, it always got my attention.
rockaduc
June 27, 2009, 02:24:08 AM »
Quote from: pennyrobber on June 26, 2009, 03:05:44 PM
The DMF: Home of the most brilliant, twisted minds since 2007.
I love this place.
Last Edit: July 05, 2009, 07:31:02 AM by rockaduc
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
June 27, 2009, 04:46:44 AM »
i kinda disagree. i think it smooths out the airflow in high speed straights. the low speed turbulence behind the fairing would tend to build up the faster you go, the airholes allows the highspeed flow to break up that lowspeed area and flow it smoother past the rider.
will be interesting to see if they reduce the height of the fairing in the future to do the same thing.
gm2
June 27, 2009, 11:36:52 AM »
Quote from: Raux on June 27, 2009, 04:46:44 AM
so why do you think we don't always see them in that case?
Like this is the racing, no?
2003 M1000s
June 27, 2009, 11:56:49 AM »
Quote from: gm2 on June 27, 2009, 11:36:52 AM
It seems like only on certain tracks they show up. Or could it be certain forecast?
The might be be placebo's too like matched tires?
homepage
http://sites.google.com/site/mittelstadtc/
fastwin
June 27, 2009, 12:09:17 PM »
I think one of the mechanics got drunk on Dutch beer and went ape shit with the drill and due to new Dorna cost cutting rules they only had the one upper fairing.
gm2
June 27, 2009, 12:17:04 PM »
i was suggesting that it's not to simply 'smooth out the airflow in high speed straights' -- or else we'd see it all the time, on all the bikes. and cars.
Novelo
June 27, 2009, 01:54:31 PM »
Guess it is for cutting down the affect of the wind issues they were having in Spain
http://www.motogpblog.com/archives/916
pg 11 Stoner suffers bad wind
http://issuu.com/motorcyclenews/docs/mcn060509?mode=embed&layout=grey
Reply #14 on:
June 28, 2009, 01:24:13 AM »
Quote from: gm2 on June 27, 2009, 12:17:04 PM
actually you might have seen it and not known it. Jim Hall used it on one of his CanAm cars. well canam was right. and jim hall did some great designs... but i miffed the make of the car wiith the holes. it was a Lola
Last Edit: June 28, 2009, 08:29:56 AM by Raux
