The Official "Show Off Your Guns" Thread
Started by zzilla, June 26, 2009, 06:11:41 PM
Quote from: fastwin on April 17, 2012, 01:25:18 PM
Ahhh... I'd just go old school and use a Rem 870 and 2.75" shells. Why mess with what works 24/7? ;)
you can modify the 870's feed ramp to take the 1.75 shells.  why mess with it?  you get 12 shells in a tube.   ;)
the modification doesn't stop you from using the 2.75 (or 3") shells.  so you can put 2 minishells in front of a magnum.  sort of a "knock knock BANG"
rgramjet
What's involved in the modification?
-Sofadriver
ducrider45
Thomas Jefferson
Quote from: rgramjet on April 17, 2012, 02:57:01 PM
The elevator arms have to be bent some to keep the minishell from flipping.
With a longer shell, the elevator is nearly flat and the lenght of the shell keeps it from flipping in the loading bay.  By bending the elevator slightly UP (into the receiver) the minishell is wedged slightly and that keeps it from flipping.
the flip happens right after the slide is moved back (and ejection is complete) when the new shell is released from the tube.  if you look closely when working the slide you can see the new shell jumping some.
obviously not an issue on the ithacas and apparently not possible to modify them.
Snake
Finally got my open gun from Freedom Gunworks.  7.5gr of Vihtavuori N350 under a 124gr CMJ at 1400fps and the dot never leaves the lens  [thumbsup]
In case the photo doesn't show up, the link is http://freedomgunworks.com/gallery/php/photo/large/Guns/DSC_0414%20(Large).JPG
2008 S2R 1000 - 2010 M1100 - 2011 Subaru WRX
What's the point of the slots on the slide?
Coolness?  Weight reduction?
I like the grips.
fastwin
Quote from: Monsterlover on May 03, 2012, 07:27:15 AM
I like the grips.
Cooling. Lightweight. Faster slide. etc. The grips are cool. Nice looking open gun.
fastwin
Snake
Chambered in regular old 9x19.  The slots in the slide are mainly for weight reduction (lighter slide = less dot movement).  The reason for no 45s in open division is the magazine restrictions.  You are limited to 170mm of length.  I can get 29 rounds in a magazine, where as you might only get 18-20 with a 45.
fastwin
What he said. [thumbsup]
Like the hooker said in Full Metal Jacket... "not you, you too big!" [laugh] [laugh]
Snake
That is a 5.4" Schuemann Ultimatch barrel.  I am loading the 9x19 at 1.165" with a Montana Gold 124 CMJ and a Federal small rifle primer.  My velocity will vary between 1390 and 1415 for a 172-175 power factor.  When loading 9-Major, you must throw all published load data out the window and cross your fingers.  I worked all of my major loads up SLOWLY with a chronograph.  I will sometimes start out using small pistol primers so I can tell when the pressure is getting high.  It looks like you poured that primer into the pocket.  With the small rifle, they have nice round edges and no flow  [thumbsup].  I still want to experiment with some HS6 and 115gr JHPs.  Now we are talking in the 1525fps range.
I haven't tried 3N37 yet, but I do have a pound.  I have a 3N38 load of 8.9gr with the same specs as my N350 load.  That was an absolute pregnant dog to get that bullet crushed down to 1.165  [bang]   The case was flush to the top with powder
Quote from: WarrenJ on May 03, 2012, 07:53:20 PM- primer must have hit the ejector or some other point causing it to detonate.
that is pretty odd, how thick is the ejector on that gun?  if the extractor is pulling correctly, it shouldn't have been open at any point to allow the ejector in.
hows the firing pin spring on that gun?
Snake
I have seen it happen on STI 2011s with long loaded .40 ammo.  It seems that all of the planets have to be in alignment for this to happen, but it IS possible
